See if you can find out what was burning. Check the old EGR transducer for melted plastic.
Many times a plugged catalytic converter will force hot exhaust gases into the base of the transducer and melt the plastic.
I would replace the EGR valve as well if the PCM is not passing an EGR test. The new valve and new transducer work together.
