1 - 2 of 2 Posts
2003 sunroof parts all busted up, replaced with NEW. Have motor out and sunroof in the closed position. Can I just stick the motor back in? calibration is a question something about aligning drive gear with white dot showing in the inspection hole?????
Discussion Starter · #2 ·
I thought it over and seeing how I had the sunroof in the closed position I hooked the motor up and ran till it stopped in the closed position, then bolted into the back. A project I won't do again, it works well and I might not ever use it again. There is no calibration that meant anything I could understand, the way I did it seemed the easiest.
1 - 2 of 2 Posts
