I keep telling people it leaks oil like a torpedoed oil tanker. So out it comes next week.
any gotchas?
why pull the whole motor? well I am primarily fixin the cam and crank seals with shaft savers etc....re-doing the water pump and of course a new belt...but while on the stand:
1) clean off the years of oil goo
2) oil pan has 2 rust pinholes, got the new pan already...
3) oil pan gasket
4) new head gaskets
5) new TTY bolts
6) new rod bearings in std
7) new mains in std
(unless I see the crank really tore up, back in it goes...the point is just to aid/restore oil clearance)
8) new intake gasket
9) new rear main
10) cut about .003 off the heads to clean them up
11) ditto oil pump
any gotchas?
3) oil pan gasket
4) new head gaskets
5) new TTY bolts
7) new mains in std
9) new rear main
11) ditto oil pump
