On my way home from Englishtown I had an "almost" overheat scare. The temp gauge went up to the line below "H". So I pulled over and noticed the fan was NOT on. By the time I opened the hood and looked at the connections the fan did turn on. So I drove the car home with the heater on Full blast (that sucked) and when there was traffic the temp went up to that line again. I did make it home watching the gauge go up to that line then down when I was driving at 60 mph.
So question #1:
On the 89 Daytona's does the fan turn on if you unplug the coolant temp sensor?
Qestion #2:
Is the fan supposed to stay running when the car is OFF until the temp goes down?
I will be changing the Thermostat and coolant sensor and antifreeze no matter what.
Also after I shut the car down at home the antfreeze in the overflow bottle was boiling and I put the fan on by putting direct power to it to cool the radiator etc. That worked.
Any other helpful hints?
Thanks....
So question #1:
Qestion #2:
Thanks....
