Don't overlook the obvious. Have you tried new bulbs? It wouldn't be the first time both bulbs burned out at the same time. It is just low beams? Do the high beams work? Did you check the fuses in the TIPM under the hood? Did you consult the owner's manual to see where the fuses are or troubleshooting?
