I need to remove the WIM from a Durango WD. So far I've removed the gauge cluster, radio/trim and the driver's lower dash. I removed two 8mm screws from the back, and now the module is a little loose. However, it won't come out of the dash. I know it's held into a larger plastic bracket with 4 screws at the front, but I can't access these with the ignition/start stop button bezel attached.
can't see any section on removing this in the shop manual I have, and can't spot anything obvious with a mirror and flashlight. My best guess is that this chrome ring and bezel unclips from the front, then the module is removed from the back. However I see no way to access or release the clips.
Anyone know the proper way to do this without breaking the trim ring? thank you
