my 95 grand caravan has trans problems. nobody around here will work on it because it is to old. what kind of scanner do i need to scan the transmission. it is in limp mode. the fuse is fine as is the relay. i have changed the output sensor and am thinking of the input sensor as well. which fixed the cruise control. now the trans and the drivers' side door latch. i also need to give it a good cleaning inside. the steering wheel was black and nasty and it rubbed off on my hands so i used a Mr. Clean magic eraser. and it cleaned up pretty well.
