Not directly, no (although that doesn't mean there ISN'T one!)
But using a Magnum 5.2/5.9 accessory drive should take care of most of the bolting-stuff-up part; or if you can find it, a 1990-1991 LA 5.2/5.9 accessory drive if you want to keep (or need to keep!) the A.I.R. pump.
And for those, worst case is a boneyard.
Do be aware that also requires replacing the water pump due to the serp design using a reverse-flow water pump.
RwP
