02 Pt LT 2.4L non-turbo A/t 206K- 1K ago t/b,w/p,idler tensioner , ex. man. rad and fan, k frame and rack and pinion cars was running great till last week seem to have a hesitation when cruzn around 1500 rpm like once before when pump failed. today brother was driving and car acted like it was running out of fuel then run ok for a minute then no throttle response and stalled, it now cranks but will not start. Fuel pressure 50 psi prime and 60 psi at crank at fuel rail. I put a spark plug in #1 wire and have fire at crank, scanner showed tcm code power up while active and theft code driver door open (i had door open while running scan and while locking and unlocking)codes cleared no returned. pulled cps swapped with one from my 07 no change also changed ckps no change, small amount of fuel in intake no start still . looking for a little direction what am i overlooking have checked all fuses and relays except the few scanner check but vehicle has to be running . Sorry for the marathon post just wanted to get what ive tested and a little history. discconnected map no change.
