1 - 7 of 7 Posts
· Registered
All Par Nation...I was hoping you could help me answer a question I had.
Is the SI-EVT Transmission that is produced at Tipton Transmsision plant in Indiana and used on the Pacifica PHEV (Windsor Assembly) the same transmission that is being used in the Grand Commander PHEV (China only vehicle). If yes, does Tipton produce this transmission and send it to China for Grand Commander assembly plant?
Both the Pacifica and Gran Commander are FWD SI-EVT's, but the Pacifica PHEV uses a 3.6L V6, while the Grand Commander uses the 2.0L I4.
Also...Pacifica PHEV is FWD only, while the Grand Commander is available in FWD or AWD, which leads me to believe that these are two different transmissions. Curious why Stellantis would have two similar low-volume applications for FWD PHEV platforms.
Thanks!
· Registered
2014 Jeep Compass
The SI-EVT seems to use the sales code DFQ for both vehicles, but with different part numbers, so it seems that they probably are the same, just with different cases to mount differently between one and the other, if not because different part numbers are sold elsewhere in the world.
Also, light research showed me a picture that is a 3D rendering of the Grand Commander's hybrid drivetrain without any driveshaft. Judging by how many articles report the GC's PHEV only having 2 electric motors, and with the SI-EVT having 2 motors within it, it's safe to say that the Grand Commander PHEV is only a FWD hybrid.
Wheel Tire Motor vehicle Automotive tire Vehicle
· Super Moderator
That would make sense. The GC only offers the 2.0L turbo with the Si-eVT (single input-electronically Variable Transaxle). The standard 2.0L NA gets the conventional 9-speed, which can be had as FWD or AWD versions.
Although slightly different in the parts illustrations, they appear to be the same transaxle.
Font Number Screenshot Parallel
Font Parallel Number Document Screenshot
Product Font Technology Auto part Engineering
Font Line Parallel Rectangle Auto part
Reactions: World14
· Registered
So does anyone know if Tipton Transmission supplies the complete Transmission to China, or is that provided by a local Transmission plant?
Products:
  • Nine-speed (948TE) transmissions
    • Jeep® Cherokee (all-wheel, four-wheel, two-wheel and hybrid drive configurations) - Belvidere, Ill.
    • Chrysler Pacifica, Chrysler Pacifica Hybrid - Windsor Assembly Plant, Ontario, Canada
    • Jeep Compass - Toluca, Mexico
    • Jeep Renegade, Fiat 500X - Melfi Assembly Plant, Italy
    • Ram ProMaster City, Fiat Ducato, Fiat Doblo - TOFAS, Turkey
    • Jeep Compass, Jeep K8 - Changsha, China
    • Jeep Compass - Ranjangaon, India
    • Jeep Renegade, Jeep Compass, Fiat Toro - Pernambuco, Brazil
· Super Moderator
Reactions: World14
· Administrator
In short, pretty much all Jeep nine-speed are supplied from Indiana, even those made in Brazil, China, India, and Italy. Something to think about when talking about how FCA “short changes” North America!
1 - 7 of 7 Posts
