1 - 6 of 6 Posts
Hi guys, i have a dodge valiant 1965 with slant 6 and A230 transmisión. I need a clutch kit but better than original, with real diafragm. Not with three lever.
Where can I found it?
Try getting ahold of Brewersperformance.com. They have what you are looking for.
Reactions: Eduardojones
First, whats wrong with the 3 lever luk style?
- the /6 clutch was the thing to go for when racing a 4 sp behind a v8 for quick shifts..
You should be able to use a v8 clutch since it works the other way around.
Discussion Starter · #5 ·
Hi, three lever clutch is not confortable and broke faster than a diafragm.
The v8 clutch Plate is diferent, and the disc diameter too. I cant use it...
It should hold up just as well as diafragm one.
( if i remember correctly you are righ about v8 clutches, its just the smaller clutch disc they use in the v8 assembly.)
Comfortable, nah itll never get as soft as a modern one in a modern car.
There is difragm clutches avail but they are quite expensive.
- what broke on the clutch?
1 - 6 of 6 Posts
