2007 nonturbo base model automatic with 120,000 miles. Car runs great with the air conditioner off, but it drops to 300 RPM occasionally when the AC compressor kicks in. Has a new tuneup with plugs, wires, and coil. I have changed PCM‘s with a known good one and it still happens. It seems to be temperature related because when the car is cold, it does not start the miss until 4 to 6 minutes after it is started. I have also run continuity checks between the clutch/pressure sensors and pcm. I’m at a loss right now so any guidance and help would be appreciated. Thank you so much.
