I am trying to change out my 7 1/4" rear end with a 8 3/4". I have the correct u- bolts for the 8 3/4" rear, but the bolts will not fit through the spring plate.
The spred of the holes is set up for the 7 1/4" rear.
I have been trying to locate some replacement plates that will work, but I can not find any.
Does anyone know where I can buy some ?
Can the hole in the plate be enlarged to make the u-bolts fit or will this make for a sloppy connection?
Is there a set of u- bolts that fit a 8 3/4" rear and then set in to fit a 7 1/4" plate?
