There is a tensioner, like a small bracket with a square hole in it, that follows the Power steering pump installation. My question is -what way should it turn? There is a bent egde on the tensioner, what way should this egde point?
Well, if it's like mine, there is a bolt that sticks out the back of the pump bracket. The other side of it bends 90 degrees and goes out the passenger side, then through another slotted hole. Then to tighten the pump, you just slightly loosen the two bolts that hold the pump on (on the side) and tighten the back bolt (which is always a pain to reach), then re-tighten the bolts at the side.
