1 - 2 of 2 Posts
I have a 2012 Town & Counrty Touring that the electric slider doors are not functioning properly. The doors lock when the unlock button is pressed and unlock when lock is pressed... the oposiite windows open when the operated by the driver's control. Any ideas? The TIPM has been replaced but that did not solve the problem.
Welcome to Allpar. Rochester, NY?
If you are still under warranty, I would let the dealer handle it. Window and door controls can act up if the switch gets wet. Can you 'make' it do it or does it happen all the time? Did they witness the problem?
Whatever diagnosis led them to the TIPM being the problem may still be present. Erratic behavior may be covered on a TSB (technical service bulletin). The only way to really diagnose and retrieve fault codes for these things is with a dealer scan tool (the WiTech).
1 - 2 of 2 Posts
