Hey A.j., I've been through my Haynes manual and can't find anything in it about the motor location. However, I'm sure it's under the dash looking at the wiring schematic. It shows that there is a dark blue with pink stripe wire that goes to the a/c zone door actuator. There is also a dark blue wire, a dark blue with gray stripe, a light green one, and a pink with dark blue wire. Next is the blend door actuator. It has a dark blue wire with red stripe, dark blue with white stripe, dark blue with gray stripe, red with white stripe and also the pink with dark blue stripe. The mode door actuator shows to have a dark blue with white stripe, dark green with yellow stripe, dark blue with gray stripe, yellow wire and a pink with dark blue stripe. Next comes the recirculation door actuator. It has a gray with dark blue stripe and a dark blue with white stripe. Last in line is the evaporator temp sensor. It also only has two wires. Dark blue with gray stripe and dark blue with orange stripe. I don't know if any of that helps you or not, but at least you have what wires go where under the dash. Maybe you can locate it by tracing the wires.
