GENERAL | A515 2.2L HPTBI (EDF) | A522 2.2L TURBO III (EDS) |
Engine assembly part no. | 4536606 | 4536619 |
Type of engine | SOHC inline 4 vertical | DOHC inline 4 vertical |
Bore | 87.5 mm | - (same) |
Stroke | 92.0 mm | - |
Stroke/Bore ratio | 1.051 | - |
Piston height TDC | 0 - 0.648 mm below deck | 0.360 mm above - 0.260 mm below deck |
Head gasket compressed thickness | 1.74 - 1.82 mm | - |
Volume - piston displacement | 2213 cc | - |
- combustion chamber w/plugs & valves | 48.5 - 51.5 cc | 57.0 - 60.0 cc |
- piston dish+valve cuts | 1.83 cc | 5.4 - 6.2 cc |
- head gasket bore allowance | 10.95 - 11.71 cc | |
- bore chamfer allowance | 0.11 - 0.31 cc | |
- piston chamfer allowance | 0.01 - 0.08 cc | 0.001 - 0.022 cc |
- total clearance | 61.40 - 69.32 cc | 71.30 - 79.80 cc |
Compression ratio | ||
Minimum:1 - Nominal:1 - Maximum:1 | 8.98 - 9.00 - 10.01 | 7.9 - 8.3 - 8.8 |
Spark plug - type/gap | Champion RN12YC / 0.035 | Champion RN9YC / 0.035 in. |
Firing order | 1-3-4-2 | |
Valve lash adjustment/cam follower - type | Hydraulic/Roller | |
Assembly weight (includes 4 qts oil & filter) | 251.2 Lbs | 364.0 lbs |
CLEARANCE DATA | ||
Crankshaft - main bearing clearance | 0.011 -0.072 mm | |
- end play | 0.05 -0.18 mm | |
- interference fit sprocket | 0.013 -0.063 mm | |
- key width to sprkt slot clearance | 0.01 -0.09 mm | |
Connecting rod large end - bearing clearance | 0.019 -0.075 mm | |
- side clearance | 0.13 -0.38 mm | |
Balance shaft gear end play | N/A | 0.100 -0.34 mm |
Oil pump - body clearance in block | 0.013 -0.114 mm | |
- outer rotor clearance in body | 0.177 -0.331 mm | |
- shaft clearance in body | 0.02 -0.06 mm | |
- shaft end play | 0.025 -0.076 mm | |
- shaft interference in gear | 0.02 -0.06 mm | |
Piston pin - interference in rod | 0.0178 - 0.0429 mm | N/A |
- clearance in rod | N/A | 0.012 -0.025 mm |
- clearance in piston | 0.006 -0.019 mm | 0.006 -0.018 mm |
- end play | N/A | 0.04 -1.02 mm |
Piston - skirt clearance @ diameter on print | 0.013 -0.038mm @ -E" | 0.047 -0.073 mm @ "Dl" & "DN" |
- skirt clr measured below head surface | 28.9 mm- 55.85 mm | |
- head land clearance (diameteral) | 0.898 -1.092 mm | |
Camshaft - journal to head clearance | 0.04 -0.082mm | 0.05 -0.100 mm |
- end play | 0.13 -0.33 mm | 0.025 -0.200 mm |
- key width to sprocket slot clearance | 0.01 -0.09 mm | 0.00 - 0.08 mm |
- nose to sprocket clearance | 0.007 -0.058 mm | 0.010 -0.055 mm |
Inter, shaft - journal to bushing clearance0.017 -0.080 mm | ||
- end play | 0.105 -0.420 mm | |
- nose to sprocket clearance | 0.007 -0.058 mm | |
- key width to sprkt slot clr | 0.01 -0.09 mm | |
Hydraulic lifter clearance - body to cyl head | 0.018 -0.069 mm | N/A |
- in rocker arm | N/A | 0.011 -0.042 mm |
Valve stem to guide clr - intake (both ends) | 0.022 -0.065 mm | 0.030 -0.060 mm |
- exhaust hot end | 0.076 - 0.119 mm | 0.300 -0.315 mm |
- exhaust cold end | 0.051 - 0.094 mm | 0.050 -0.080 mm |
Rocker arm - to spring retainer - minimum clr | 1.25 mm | N/A |
- to shaft clearance | N/A | 0.96 - 0.967 mm |
Turbocharger rotating aasy - radial clearance | N/A | 0.076 -0.145 mm |
- axial end play | N/A | 0.013 - 0.081 mm |
30A01 - CYLINDER BLOCK | A515 2.2L HPTBI (EDF) | A522 2.2L TURBO III (EDS) |
Part number (assembly) | 4556032 | 4621029 |
Main bearing bore - I.D. | 63.992 - 64.013 mm | |
- align, bar dia. @ | 21 (70~F) | 63.9770 ± 0.0025 mm |
- length #1 | & #5 | 25.0 mm |
- length #2 | & #4 | 24.0 mm |
- length #3 | 23.48 - 23.53 mm | |
Cylinder bore diameter finishes @ 21~ (70°F)- | ||
A size | 87.468 -87.480 mm | N/A |
B size | 87.481 - 87.493 mm | |
C size | 87.494 - 87.506 mm | |
D size | 87.507 - 87.519 mm | |
E size | 87.520 - 87.532 mm | N/A |
Cylinder -out of round - maximum | 0.025 mm | |
bore taper after honing - maximum | 0.025 mm | |
bore finish | 0.50 -0.88 um | |
- head oil restrictor P/N | N/A | 4323808 |
- head oil restrictor diameter | N/A | 2.93 - 3.43 mm |
Breather vent - nipple P/N | N/A | 4387304 |
- bore diameter | N/A | 15.80 - 15.85 mm |
Crankshaft centerline - to block deck surface | 237.67 - 237.93 mm | |
-to chamber @ bottom of bore | 86.5 mm | |
Block deck - flatness | 0.012 mm / 51 mm any direction | - |
- micro finish | 2.0 - 3.8 um | |
Inter, shaft bearing bore -diameter - front | 45.97 - 46.03 mm | |
diameter - rear | 22.97 - 23.03 mm | |
-length - front | 20.88 - 20.96 mm | |
-length - rear | 22.0 mm | |
Plug - oil gallery (2 req'd) - P/N | 4556018 | - P/N4556022 |
- core hole (5 req'd) | (5/8 in. Ø) | (1.625 in. Ø) |
Distributor - bore diameter | 27.015 - 27.090 mm | N/A |
- clamp P/N | 4179922 | N/A |
Oil pump bore diameter | 36.073 - 36.134 mm | |
Dowel -cyl head attachment (2 req'd) - P/N | 6500402 | |
bal/shft carrier att (2 req'd) - P/N | N/A | 6500402 |
crank seal ret att (2/retainer) - P/N | 5203466 | |
-clutch/trans hsg att (2 req'd) - P/N | 5240849 | |
Dipstick tube hole diameter | 10.29 - 10.35 mm | |
Cross drill hole diameter | N/A | 3.5 - 4.0 mm |
30A01 - TIMING BELT COVER | ||
Cover - upper assembly - P/N | 4448634 | 4442821 |
- lower assembly - P/N | 4667247 | 4442822 |
Plug - upper cover - P/N | 2094631 | N/A |
- lower cover - P/N | 4448725 | N/A |
Flap / staple - upper cover - P/N | 4343823 / 6033112 | N/A |
Seal strip - upper cover edge - P/N | N/A | 4484312 (68 - 72 mm long) |
- upper cover edge - P/N | N/A | 4484313 (178 - 182 mm long) |
30A02A - CRANKSHAFT BEARING | ||
Part numbers | ||
- #1. 2. 4, 5 lower | 5203355 (CL-66). OPT 4621132 (AL-6M) | 5203355 |
#3 lower | 5203376 (CL-66), OPT 4621146 | (AL-6M) |
- #1. 2, 4, 5 upper | 5203355 (CL-66). OPT | 4621132 (AL-6M) 5203355 |
#3 upper | 5203369 (CL-66). OPT | 4621139 (AL-6M) |
- Wall thickness @ 90° to parting line - | CL-66 1.977 - 1.984 mm- | AL-6M 1.976 - 1.984 mm |
Bearing length | ||
-#1. 2. 4, 5 | 21.36 - 21.61 mm | |
#3 | 27.80 - 27.87 mm | |
Flange thickness- #3 | 2.09 - 2.14 mm | |
Bearing material | - CL-66 | Pb/Al, Steelbacked; MS-5557 |
- | AL-6M | Pb/Al, Steelbacked; MS-7651 |
Liner thickness at center - #1, 2, 3, 4, 5 | 0.13 - 0.50 mm | |
Bearing inspection process standard | PS-771 & PS-1159 | |
Crush height at total load | 0.020 - 0.060 mm @ 4900 N | |
Oil hole - dia. - #1. 2, 3, 4, 5 | 6.25 - 6.75 mm | |
Sizes released STD, | .025. .050, .25. .275, .300 mm U/S | |
Shell taper - measured from parting line ( less than center thickness ) | ||
#1, 2, 4, 5 | - CL-66 | 0.007 - 0.015 mm |
#3 | - CL-66 | 0.0076 - 0.0152 mm |
#1, 2, 4, 5 | - AL-6M | 0.007 - 0.017 mm |
#3 | - AL-6M | 0.0076 - 0.0176 mm |
30A02A - CRANKSHAFT BEARING CAP | ||
Part numbers - #1. 2, 3, 4, 5 | 4483261, 4483262, 4483263, 4483264. 4483265 | |
Part number | 4448496 | 4536082 |
Material | Nodular Cast Iron MS-4561 | Steel MS-4925 |
Number of flange attachment holes | 8 | |
Number, of main bearings | 5 | |
Thrust taken by | #3 bearing | |
Main bearing journal - diameter | 59.987 - 60.013 mm | |
- out of round | 0.008 mm | |
- taper - maximum | 0.008 mm | |
- finish - maximum | 0.38 um | |
- fillet radii | 1.45 - 1.65 mm | |
Main bearing thrust surface finish - maximum | 0.63 um front / 0.38 um rear | |
Main bearing journal length between thrust surfaces | ||
- #1 | 25.87 - 26.13 mm | |
#2, 4, 5 | 27.87 - 28.13 mm | |
#3 | 27.96 - 28.04 mm | |
Crankpin - diameter | 49.979 - 50.005 mm | |
- length between thrust surfaces | 25.9 - 26.1 mm | |
Center bearing runout - supported at front & | ||
rear main (maximum) | 0.08 mm | |
Crankshaft diameter - sprocket hub | 25.475 - 25.500 mm | |
- front seal journal | 28.462 - 28.538 mm | |
- rear seal journal | 90.920 - 91.080 mm | |
Crankshaft seal journal finish | 0.15 - 0.63 um | |
Angle between crank throws | 180° | |
Centerline main to centerline crankpin | 45.92 - 46.08 mm | |
Imbalance - maximum | 25 gm-cm (0.35 in-oz) | |
Index tolerance on sprocket keyway | ± 0° 20' | |
Flange - O.D. circular runout | 0.08 mm | |
- face flatness | 0.025 mm | |
- hub O.D. | 47.95 - 48.00 mm | |
- hub concentricity O.D. | 0.05 mm | |
- pilot I.D. | 33.981 - 34.019 mm | |
- pilot I.D. concentricity | 0.09 mm | |
Sprocket fillet radii | 1.45 - 1.65 mm | |
30A02A - CRANKSHAFT SEAL & RETAINER | ||
FRONT: Seal Part number | 4273275 | |
Seal material | MS-BZ726 | |
Retainer Part number | 4387579 | 4484390 |
Retainer bore diameter | 41.225 - 41.275 mm | |
Assembly Part number | 4387580 | 4536309 |
REAR: Seal Part number | 5203590 | |
Seal material | MS-BZ820 | |
Retainer Part number | 5214782 | |
Retainer bore diameter | 110.97 - 111.02 mm | |
Assembly Part number | 5214784 | |
30A02A - CRANKSHAFT SPROCKET | ||
Part number | 4483298 | 4442973 |
Number of teeth | 20 | |
Pitch diameter (reference) | 60.6380 mm | |
Reamed I.D. | 25.437 - 25.462 mm | |
Tooth - finish - maximum | 1.6 um | |
- profile drawing | 4483298 4442964 (20T RPP) | |
Material | MS-589-A-2 | MS-2282 |
Pilot insert - P/N | N/A | 4483486 |
Key slot width | 4.03 - 4.08 mm | |
Sprocket key - P/N | 6500150 | |
- width | 3.99 - 4.02 mm. | |
30A02A - TIMING BELT | ||
Part number | 4387549 | 4484494 |
Number of teeth | 124 | 131 |
Tolerance - each edge - maximum | 0.75 mm T.I.R. | |
Belt material/color ident/vendor | MS-EB119/green/Gates | HSN/none/Pirelli |
Pitch | 9.525mm (0.375 in.) | |
Belt width | 23.3 - 24.3 mm | 29.2 - 30.8 mm |
30A02A - TIMING BELT TENSIONER | A515 2.2L HPTBI (EDF) | A522 2.2L TURBO III (EDS) |
Part number | 4315705 | 4484464 |
Tension on Burroughs gauge - new belt | 50 -70 lbs | 100 - 110 lbs |
Pulley - flat diameter | 71.5 - 72.5 mm | 75.8 - 76.2 mm |
- pitch diameter (reference) | 75 mm | 77.5 mm |
- width at pitch diameter | 25.7 - 26.3 mm | 34.5 - 36.1 mm |
30A02A - TIMING BELT IDLER | ||
Part number | N/A | 4484465 |
Pulley - flat diameter | 59.8 - 60.2 mm | |
- pitch diameter (reference) | 61.5 mm | |
- width at pitch diameter | 34.8 - 36.3 mm | |
30A02A - BALANCE SHAFT SPROCKET-CRANKSHAFT | ||
Material | MS-589-B3 | |
Number of teeth / pitch | 36 / 7.774 mm | |
Pitch diameter | 89.2 mm | |
30A02A - BALANCE SHAFT DRIVE CHAIN | ||
P/N | N/A | 4273260 |
Type | Single row, roller | |
Length between centers | 126.30 - 126.55 mm @ 156.6 N load | |
Pitch | 7.774 mm (non-adjustable) | |
30A02B - BALANCE SHAFT CARRIER | ||
Carrier assembly - P/N | N/A | 4556231 |
Bearing diameter - front | 25.06 - 25.08 mm | |
- rear | 42.06 - 42.08 mm | |
Bearing surface finish - front / rear - maximum | 0.75 / 1.0 um | |
Rear bearing - P/N | 4273252 | |
- material | Pb/Al. steelbacked; MS-7651, OPT MS-5557 | |
- crush height | 0.000 - 0.048 mm @ 2560 N | |
- press fit | 0.12 - 0.19 mm | |
- press in load - minimum | 2600 lb. | |
Plug - oil feed (1 req'd) - P/N | 5203517 (7/16 in. Ø) | |
Cover - carrier gear - P/N | 4323039 | |
Dowel - carrier gear cover att (2 req'd) - P/N | 5203466 | |
Trough - carrier gear cover - P/N | 4323041 | |
Rear cover - P/N | 4323043 | |
30A02B - BALANCE SHAFT | ||
Driver (OR) - P/N | N/A | 4621088 |
Driven (ON) - P/N | 4621089 | |
Material | Nodular Iron, MS-3996A | |
Journal - diameter - front | 24.99 - 25.01 mm | |
- diameter - rear | 41.99 - 42.01 mm | |
- roundness & taper | 0.012 mm T.I.R. | |
- finish (front & rear) - maximum | 0.25 um | |
Imbalance - maximum | 7.68 in-oz. | |
30A02B - BALANCE SHAFT GEAR | ||
Driver (DR) - P/N | N/A | 4343783 |
Driven (DN) - P/N | 4343785 | |
Type. | 30 teeth - DR / ON Right helix / Left helix | |
Material | MS-891 | |
Thrust surfaca finish - maximum | 0.63 um | |
Measurement over two 3.175 mm diameter balls | 62.710 - 62.799 mm | |
Gear tooth root hardness @ 0.75 mm minimum depth | HRC 48 - 52 | |
Key - P/N | 6500150 | |
30A02B - BALANCE SHAFT DRIVER SPROCKET | ||
P/N | N/A | 4483485 |
Number of teeth / pitch | 18 / 7.774 mm | |
Pitch diameter | 44.77 mm | |
30A02B - BALANCE SHAFT CHAIN TENSIONER & GUIDE | ||
Tensioner - P/N | N/A | 4343662 |
Clearance, chain to tensioner, | ||
Apply 5.5 - 6.5 lb tangental load w/1 mm shim | 1 mm over 70 mm span | |
Guide, non-adjustable - P/N | 4343660 | |
30A03 - CONNECTING ROD | ||
Part number - assembly - with warm formed cap | 4387736 | 4556210 |
- with hot forged cap | 4387737 | N/A |
Bearing bore - center to pin bore center | 150.95 - 151.05 mm | |
- finish - maximum | 1.5 um | |
- diameter | 52.992 - 53.008 mm | |
Bearing end width | 25.72 - 25.77 mm | |
Piston pin - bore finish - maximum | 3.2 um | 1.5 um |
- bore diameter | 22.840 - 22.860 mm | 24.587 - 24.638 mm (w/o bushing) |
- end width | 25.70 - 25.78 mm | |
- bore to bearing bore parallelism | 0.08 mm | 0.02 mm |
- bore to bearing bore twist | 0.08 mm | 0.04 mm |
Bolt hole I.D. | 9.89 - 9.93 mm | |
Material | MS-405 | |
Hardness | 229 - 269 HRB | |
Assembly mass - large end | 514.5 - 518.5 g 512.5 - 516.5 g | |
- small end | 127 - 151 g | 189.2 - 191.2 g |
30A03 - CONNECTING ROD PISTON PIN BUSHING | ||
Part number | N/A | 4536094 |
Material | Bronze on steel; MS-1900, OPT MS-2164 | |
Thickness - before rod assembly | 1.127 - 1.254 mm | |
I.D. - finished rod assembly | 22.895 - 22.903 mm | |
I.D. finish - maximum | 1.5 um | |
30A03 - CONNECTING ROD ATTACHMENT | ||
Bolt - P/N | 4448934 (double knurll) | 4536307 |
- thread size | 3/8-24 UNF-3A (rolled) | |
- material - property class analysis | MS-3049 | |
- shank diameter | 0.343 - 0.348 in. | |
- length | 2.22 - 2.26 in. | 2.06- 2.10 in. |
- hardness | 34- 38 HRC | 39-43 HRC |
Nut - P/N | 4227678 (flanged) | 4536306 (no flange) |
- thread size | 3/8-24 UNF-3B | |
- material - property class analysis | MS-5820 | |
- hardness | 28-34HRC | 30-36HRC |
30A03 - CONNECTING ROD BEARING | ||
Part number | 4536284 (AL-6M), OPT 5203390 (CL-66) | 4105240 (H-24) |
Bearing material | Pb/Al, Steelbacked | Cu/Pb, Steelbacked |
MS-7651, OPT: MS-5557 | MS-4790 | |
Wall thickness at 90° to parting line length | 570 1.476 - 1.484 mm | 1.471 - 1.484 mm |
OPT | 1.477 - 1.484 mm | |
Bearing length | 19.90 - 20.16 mm | |
Liner thickness at center of bearing | 0.13 - 0.50 mm | |
Inspection process standard | PS-771 & PS-1159 | |
Sizes released | STD; 0.025, 0.050, 0.250, | STD; 0.050. 0.250, 0.275, |
0.275. 0.300 mm U/S | 0.300 mm U/S | |
Shell taper - measured from parting line | 0.005 - 0.013 mm | |
Crush height at total load | 0.045 - 0.085 mm @ 2450 N | |
30A03 - PISTON | ||
Part number | 4556180 | 4315268 |
Skirt sizing dia., below head surface | 28.9mm | 55.85mm |
- A size | 87.442 -87.455 mm | 87.407 -87.420 mm |
- B size | 87.455 -87.468 mm | 87.420 -87.433 mm |
- C size | 87.468 -87.481 mm | 87.433 -87.446 mm |
- 0 size | 87.481 -87.494 mm | 87.446 -87.459 mm |
- E size | 87.494 -87.507 mm | 87.459 -87.472 mm |
Skirt taper | ||
- max. dia., increase over sizing dia. | 0.00 - 0.015 mm | Barrel profile |
- bottom dia., decrease over sizing dia. | 0.025 - 0.075 mm | |
Ring groove width - upper & 2nd | 1.528 - 1.553 mm | 1.530 - 1.550 mm |
- 3rd | 4.010 - 4.035 mm | 3.010 - 3.030 mm |
Centerline piston pin to top of head (Piston compression height) | 40.412 - 40.540 mm | 40.80 - 40.90 mm |
Overall height | 71.05 - 71.55 mm | 65.55 - 66.15 mm |
Pin bore - diameter | 22.8892 - 22.8968 mm | 22.889 - 22.896 mm |
- to skirt squareness | 0.001 mm/mm | 0.0005 mm/mm |
- offset to major thrust side | 1.5 mm | 0.9 - 1.1 mm |
Finished mass . | 430 - 440 g | 415 - 425 g |
Type of piston - aluminum | Cast w/steel struts-4323604 | Forged |
Material - aluminum (excl struts) | MS-3012 | MS-7438 |
Hardness - aluminum | 95 - 125 BHN | 90 - 120 BHN |
Coating | Tin plate, PS-1751 | |
Sizes released | STD; 0.50 mm 0/S | STD |
30A03 - PISTON PIN | A515 2.2L HPTBI (EDF) | A522 2.2L TURBO III (EDS) |
Part number | 1947351 | 4315352 |
- finished - measured at 21°C | 22.8778 - 22.8829 mm | 22.878 - 22.883 mm |
Length | 74.80 - 75.82 mm | 63.7 - 64.0 mm |
Wall thickness - minimum | 3.38 mm | 4.389 mm |
Surface finish - maximum | 0.15 um | 0.07 um |
Material | MS-301 | Mahle-class L (17Cr3) |
Mass - calculated - nominal | 126.8 g | 129.2 g |
30A03 - PISTON PIN RETAINER | ||
Part number | N/A | 4483495 |
Material | MS-5795 | |
Wire diameter | 1.56 - 1.64 mm | |
30A03 - PISTON RING - UPPER | ||
Part number | 4323259 | 4315339 |
Width | 1.475 - 1.490 mm | |
Radial wall thickness | 3.72 - 3.96 mm | 3.35 - 3.70 mm |
Tangential tension @ 87.5 mm gage diameter | 17 - 29 N | 8.2 - 12.3 N |
Flatness | 0.05 mm | N/A |
Concentricity (1.0. to 0.0.) | 0.25 mm | 0.18 mm |
Gap @ 87.5 mm gage diameter | 0.25 - 0.51 mm | 0.3 - 0.5 mm |
Type | No twist | |
Face - coating - Molybdenum | PS-4494B | (Goetze MP96A) |
- finish - maximum | Barrel lap | 16 um |
Inspection standard | PS-1029 | N/A |
Identification markings | Sealed Power | GDE Z MP96A TOP K |
Perfect Circle | o Muskegon | |
30A03 - PISTON RING - INTERMEDIATE | ||
Part number | 5203330 | 4315270 |
Width | 1.46- 1.49 mm | 1.475 - 1.490 mm |
(1.5 max after coating) | ||
Radial wall thickness | 3.87- 4.11 mm | 3.35 - 3.70 mm |
Tangential tension @ 87.5 mm gage diameter | 23.5- 36.0 N | 7.5 - 11.2 N |
Gap @ 87.5 mm gage diameter | 0.28- 0.53 mm | 0.3 - 0.5 mm |
Type | Reverse twist | No twist |
Coating (all over) | PS-863 B4 (Lubrite) | N/A |
Face - finish | Turned | 3-16 um |
- taper | 1°30' - 2°30' | 1°00' - 2°00' |
Material | MS-3744(Goetze std) | |
Sizes released | STD; | 0.50 mm 0/S STD |
Identification markings | - Sealed Power | GOE Z TOP |
30A03 - PISTON RING - LOWER | ||
Part number | 4201962 | 4442959 |
Width - maximum | 0.49 mm | 2.975 - 2.990 mm |
Radial wall thickness | 2.72 -2.88 mm | 2.65 -3.00 mm |
Tangential tension @ 87.5 mm gage diameter | N/A | 38.0 -53.0 |
Concentricity (1.0. to 0.0.) | N/A | 0.18 mm |
Gap @ 87.5 mm gage diameter | 0.25 -1.27 mm | 0.25 -0.50 mm |
Free gap | 0.77 - 3.94 mm | N/A |
Surface treatment | PS-1129 | (Goetze) |
Face coating | PS-1217 | Chrome |
Chrome thickness - minimum | 0.05 mm | 0.06 mm |
Face finish - maximum | Lapped or Ground | 3 um |
Number per piston | 2 | 1 |
Material | MS-2015 (Goetze std) | |
Hardness | HR 30N-68-72 | N/A |
Width - 2 rails+spacer - maximum | 4.005 mm | (see above) |
30A03 - PISTON RING SPACER - LOWER | A515 2.2L HPTBI (EDF) | A522 2.2L TURBO III (EDS) |
Part number | 4201965 | N/A |
Tangential. tension @ 87.5 mm gage diameter | 22.5 - 48.5 N | |
Material | HS-3458A or MS-605 | |
Width | 3.73 - 3.92 mm | |
Free gap | 0.0 - 6.4 mm | |
Stock thickness | 0.435 - 0.485 mm | |
O.D. @ 0 gap | 86.91 - 87.53 mm | |
Identification markings | o -Perfect Circle | 1 - Muskegon |
.S or No mark -Sealed Power | H - Hastings | |
Sizes released | STD; 0.50 mm | 0/S |
30A04A - CAMSHAFT | ||
SOHC - intake & exhaust - P/N | 4387850 | N/A |
DOHC - intake / exhaust - P/N | N/A | 4442937 / 4442938 |
- intake / exhaust - assy P/N | N/A | 4442940 / 4442941 |
Material | MS-3996-A | |
Bearing journal diameter | 34.939 - 34.960 mm | 47.925 - 47.950 mm |
Bearing journal length - #1 (w/o chamfers) | 28.09 - 34.41 mm | 26.7 - 27.3 (w/5mm slot) |
- #2, 3, 4 | 17.25 - 17.75 mm | N/A |
- #5 thrust - minimum | 14.6 mm | N/A |
- #2. 3, 4, 5 - nominal | N/A | 16.0 mm (w/o chamfers) |
- #6 thrust - nominal. | N/A | 19.0 mm (w/o chamfer) |
SOHC - width between thrust surfaces | 21.45 - 21.55 mm | N/A |
DOHC - width between intake cam thrust surfaces | N/A | 12.2 - 12.3 mm |
DOHC - width between exhaust cam thrust surfaces | N/A | 10.2 - 10.3 mm |
Bearing journal finish - maximum | 0.40 um | 0.38 um |
Lobe - basecircle diameter - intake & exhaust | 35.4057 - 35.6597 mm | 33.7392 - 33.8192 mm |
- basecircle runout - maximum | 0.050 mm T.I.R. | 0.020 mm T.I.R. |
- centerline to key slot error | ± 0.5° | |
- length | 15.9 - 17.4 mm | 16.0 - 17.5 mm |
- surface finish - maximum | 0.50 um | 0.38 um |
Lobe surface hardness - 180° of base circle | 51 HRC (minimum) | N/A |
- 180° including nose | 55 HRC (minimum) | N/A |
- DOHC camshafts | N/A | 50 - 55 HRC |
Depth of lobe hardness - 180° of base circle | 0.76 - 3.81 mm | N/A |
- 180° including nose | 0.76 - 5.59 mm | N/A |
- DOHC camshafts | N/A | 1.0 mm |
Core & brg journal. hardness | 229 - 302 HB | 255 - 311 HE |
Cam lift - intake & exhaust | 6.23289 mm | 4.80000 mm |
Valve lift - intake & exhaust | 10.992 mm | 8.550 mm |
Thrust surface finish - maximum | 0.80 um | |
Key offset to #1 lobe | 47.2° (exhaust lobe) | 0° |
Sprocket key slot width | 3.96 - 3.99 mm | 3.94 - 3.96 mm |
Valve duration - intake - nominal | 236° | 190° |
- exhaust - nominal | 232° | 188.5° |
Intake opens - nominal. | 0° (TDC) | 25° ATDC (at 1.27 mm lift) |
Intake closes - nominal | 56° ABDC | 35° ABDC (at 1.27 mm lift) |
Valve overlap - nominal | 8° | -32.5° (at 1.27 mm lift) |
Exhaust opens - nominal. | 44° BBDC | 16° BBDC (at 1.27 mm lift) |
Exhaust closes - nominal | 8° ATDC | 7.5° BTDC (at 1.27 mm lift) |
SOHC - centerline (#1 intake) - nominal | 118° | N/A |
DOHC - centerline (#1 intake) - nominal | N/A | 121° |
- centerline (#1 exhaust) - nominal | N/A | 104° |
Centerline designed tolerance | ± 2° | |
Journal diameter - front seal | 34.939 - 34.960 mm | 37.84 - 38.00 mm |
- real seal | 34.86 - 35.02 mm | N/A |
Journal finish - front seal | 0.15 - 0.50 um | 0.20 - 0.63 um |
- rear seal | 0.15 - 0.63 um | N/A |
Shaft diameter @ aprocket hub | 23.487 - 23.513 mm | 25.375 - 25.390 mm |
Sizes released (journal diameter) | STD; 0.50 mm 0/S | STD |
30A04A - CAMSHAFT BEARING CAP | ||
Part number - #1, 5 | 5203731, 5203737 | N/A |
- #2, 3, 4 (w/oil squirt slots) | 5203733, 5203734, 5203735 | |
- OPT: #2, 3, 4 (w/o oil slots) | 5281132, 5281134, 5281136 | |
Material - die cast aluminum | MS-2410D | |
Cap bore bearing length - #1, 2, 3, 4 | 17.3 - 17.7 mm | |
Parting line surface to flat & true within | 0.025 FIR | |
30A04A - CAMSHAFT SEAL | ||
Part number (front) | 4105395 | 4424059 |
Material | MS-BZ726 | N/A |
Part number (rear) | 4343903 | N/A |
Material | MS-BZ725 | |
Pressed ball plug - front oil seal - P/N | N/A | 4442117 |
- depth | N/A | 34.5 - 36.0 mm |
Screw plug - rear oil meal - P/N | N/A | 4424096 |
30A04A - CAMSHAFT RETAINER | A515 2.2L HPTBI (EDF) | A522 2.2L TURBO III (EDS) |
Part number - intake camshaft | N/A | 4484404 |
Intake retainer width | 11.950 - 12.025 mm | |
Part number - exhaust camshaft | N/A | 4484405 |
Exhaust retainer width | 9.950 - 10.025 mm | |
30A04A - CAMSHAFT SPROCKET | ||
SOEC - P/N | 4387557 | NIA |
DOHC - intake - P/N | N/A | 4442871 |
- exhaust assy P/N | N/A | 4484263 |
Number of teeth | 40 | |
Pitch diameter (reference) | 121.276 | |
Reamed I.D. | 23.520 - 23.545mm | 25.40 - 25.43 mm |
- profile drawing | 4387557 | 4442965 |
Material | MS-588-B-2 | MS-2282 |
Key slot width | 4.03 - 4.08 mm | 3.99 - 4.04 mm |
Sprocket key - P/N | 6500150 | 4442045 |
- width | 3.99 - 4.02 mm | 3.96 - 3.99 mm |
30A04B - INTERMEDIATE SHAFT | ||
Part number | 4343428 | 4556214 |
Pitch diameter of gear | 33.093 mm | |
Bearing journal -diameter - front | 42.670 - 42.703 mm | |
...-diameter - rear | 19.670 - 19.703 mm | |
- length - front - nominal | 20.0 mm | |
- length - rear - nominal | 22.5 mm | |
- finish | 0.40 - 2.50 um | |
Gear - blank hardness | 229 - 286 HB | |
- tooth forming | Bobbed | Bobbed & Shaved |
- tooth flank finish - maximum | 2.03 um | 0.64 um |
Seal journal - diameter | 34.975 - 35.025 mm | |
- finish | 0.15 - 0.63 um | |
Shaft diameter @ sprocket hub | 23.487 - 23.513 mm | |
30A04B - INTERMEDIATE SHAFT BUSHING | ||
FRONT: Part number | 4387691 | |
Bearing finish I.D. after reaming | 42.72 - 42.75 mm | |
...O.D. (free state) | 46.32 - 46.55 mm | |
...Length incl l.1/1.9x15° O.D. chamfer | 18.5 - 19.5 mm | |
...Material (Babbitt on steel) | MS-1680, OPT MS-2012 | |
REAR: Part number | 5203468 | 4621161 (double slot) |
Bearing finish 1.0. after reaming | 19.72 - 19.75 mm | |
0.0. (free state) | 23.32 -23.55mm | |
...Length incl l.1/1.9x15° 0.0. chamfer | 20.5 -21.5 mm | |
...Oil slot angle relative to shaft centerline | N/A | 29.5° - 30.5° |
...Oil slot min. width in babbitt after forming | N/A | 1.27 mm |
30A04B - INTERMEDIATE SHAFT SEAL & RETAINER | ||
Assembly - P/N | 5203325 | 4484070 |
Seal - P/N | 4105388 | |
- material | MS-BZ726 | |
Retainer - P/N | 5203319 | |
- seal bore diameter | 51.975 - 52.025 mm | |
30A04B - INTERMEDIATE SHAFT SPROCKET | ||
Part number | 4387557 | 4443000 |
Number of teeth | 40 | 30 |
Pitch diameter (reference) | 121.276 | 90.96 |
Reamed 1.D. | 23.520 - 23.545 mm | |
- profile drawing | 4387557 | 4442966 |
- width | 3.99 - 4.02 mm | |
3OAO5A - ENGINE LIFT BRACKET | ||
Right side - P/N | N/A | 4484376 |
Left side - P/N | N/A | 4484377 |
Part number (w/o guides, seats, plugs or studs) | 4105783 | 4484450 |
Material | MS-6876 (AA319 alloy) | MS-6876 (AS 7 U3 alloy) |
Combustion chamber design | Fastburn | Hemispherical |
Camshaft - bearing bore diameter | 35.000 - 35.021 mm | 48.000 - 48.025 mm |
- bore centerline to deck | 158.37 - 158.73 mm | 98 mm (reference) |
Intake to exhaust cam bore centerline | N/A | 100 mm (reference) |
Valve seat counterbore diameter - intake | 42.275 - 42.300 mm | 35.800 - 35.625 mm |
- exhaust | 36.715 - 36.740 mm | 32.500 - 32.525 mm |
Intake & exhaust valve guide counterbore dia. | 12.467 - 12.500 mm | 11.500 - 11.513 mm |
Reference valve angle - intake | 7.5° | 15.5° |
- exhaust | 7.5° | 14.0° |
Seal bore diameter - front | 51.98 - 52.02 mm | 50.000 - 50.039 mm |
- rear | 53.23 - 53.27 mm | N/A |
Rocker shaft bore diameter | N/A | 20.96 - 21.09 mm |
Coolant outlet diameter | 36.5 - 37.0 mm | 41.75 - 42.25 mm |
Plug - core (2 req�d) - P/N | 4556020 (1.25 in. ø) | 4424085 (49 mm ø) |
- oil. gallery (2-EDF,1-EDS) - P/N | 4556018 (5/8 in. ø) | |
- (1 req�d) - P/N | N/A | 5203517 or 4556017 (7/16 in. ø) |
- oil gallery (1 req�d) - P/N | N/A | 4484426 (8 mm ø) |
Block face finish - maximum | 2.0 um | |
Specified hardness (BHN) | 70 | 100 - 130 |
Valve lash adjuster bore diameter | 15.931 - 15.969 mm | N/A |
3OAO5A - CYLINDER HEAD GASKET | ||
Part number | 5281064 | 4424060 |
3OAO5A - WATER BY-PASS TUBE | ||
Assy - P/N | 4273489 | N/A |
Bracket - P/N | 5281186 | |
30A05B - CYLINDER HEAD) COVER | ||
SOHC - cover assy - P/N | 4343496 | N/A |
- curtain - P/N | 4667174 | |
- curtain retainer - P/N | 4387331 | |
DOHC - intake cam - P/N | N/A | 4484462 |
- exhaust cam - P/N | 4484463 | |
- spark plug cover - P/N | 4442807 | |
Gasket - P/N | N/A | 4484489 |
End seals - P/N | 5214479 | N/A |
Oil fill cap - P/N | 4621012 | 4484490 |
30A06 - INTAKE VALVE | ||
Part number | 4298137 | 4484421 |
Material | MS-3049 | HNV 3 |
Head O.D. | 40.47 - 40.73 mm | 33.76 - 34.00mm |
Face - angle (from valve axis) | 45.0° - 45.5° | 45.25° -45.75° |
- finish - maximum | 0.63 um | 0.8 um |
Length - overall | 113.93 - 114.57 mm | 145.3 - 145.7mm |
Stem - diameter | 7.935 - 7.953 mm | 6.955 - 6.970mm |
- finish - maximum | 0.3 um | 0.2 um |
- tip finish - maximum | 0.5 um | |
- runout with seat - maximum T.I.R. | 0.04 mm | 0.03 mm |
- coating | Flash chrome (PS-3832) | |
Sizes released | STD;0.15, 0.40, 0.80 mm 0/S | STD |
30A06 - EXHAUST VALVE | ||
Part number | 4298142 | 4484422 |
Head material | MS-3262-B-1 (21-2N) | MS-6788 (Inconel. 751) |
Head 0.D. | 35.275 - 35.525 mm | 29.13 - 29.40 mm |
Face - angle (from valve axis) | 45.0° - 45.5° | 45.25° - 45.75° |
Length - overall | 114.55 - 115.19 mm | 143.5 - 143.9 mm |
Stem - material | MS-374 or modified MS-2249 | Steel-HNV 3 |
- diameter - cold end | 7.906 - 7.924 mm | 6.935 - 6.950 mm |
- diameter - hot end | 7.881 - 7.899 mm | 6.6 - 6.7 mm |
- runout with seat - maximum | 0.04 mm T.I.R. | 0.03 mm |
...- coating | Heavy chrome (PS-3832) | |
Sizes released | STD; 0.15, 0.40, 0.80 mm 0/S | STD |
30A06 - VALVE STEM SEAL | ||
Part number | 4201332 | 4424030 |
Material | BZ720 | N/A |
Sizes released | STD; | 0.15, 0.40, 0.80 mm 0/S STD |
30A06 - VALVE SEAT | A515 2.2L HPTBI (EDF) | A522 2.2L TURBO III (EDS) |
(as installed dimensions) | ||
Intake - P/N | 5203472 | 4442763 |
- seat major diameter | 40.22 - 40.48 mm | 33.75 - 34.25 mm |
- seat width | 1.75 - 2.25 mm | N/A |
- seat angle from valve axis | 44.5 - 45.0° | 44.75° - 45.25° |
- face finish - maximum | 1.25 um | 0.4 um |
- material | MS-6946 | Goetze PMF 4 |
- sizes released | STD; 0.20 mm 0/S | STD; 0.127 mm 0/S |
Exhaust - P/N | 5203792 | 4442903 |
- seat major diameter | 34.61 - 34.87 mm | 29.15 - 29.65 mm |
- seat width | 1.50 - 2.00 mm | N/A |
- material | MS-6883, OPT MS-7233 | Goetze PMF 15 |
Intake & Exhaust - maximum T.I.R. runout | 0.05 mm | 0.07 mm |
- maximum out of round | 0.013 mm | |
30A06 - VALVE GUIDE | ||
Intake - P/N | 4483714, OPT 4621122 | 4484408 |
Exhaust - P/N | 4483711, OPT 4621125 | 4484408 |
Intake & Exhaust - material - powder metal | MS-8328, OPT MS-8915 | MS-7843 |
- finished 1.D. | 7.975 - 8.000mm | 7.000 - 7.015 mm |
...- 1.D. finish | 1.6 - 5.0 um | 1.6 um (maximum) |
- height above head boss | 8.5 - 9.5 mm | 6.3 - 7.3 mm |
...- sizes released | STD; 0.025 mm 0/S | STD; 0.127 mm 0/S |
30A06 - VALVE SPRING | ||
Part number (assembly) | 4448305 | 4442213 |
Material | MS-820 | BS 2803 730 A65 HD |
Number of coils - total | 6.50 | 6.99 - 7.01 |
- active (approximate) | 4.63 | 5 |
Wire diameter | 4.71 - 4.76 mm | 4.712 - 4.788 mm |
Free length | 54.9 mm | 53.2 mm |
Solid height - maximum | 29.6 mm | 32.7 mm |
Load - valve closed | 480 - 534 N @ 41.9 mm | 513 - 567 N @ 44.0 mm |
- valve open | 890 - 961 N @ 31.0 mm | 1133 - 1227 N @ 34.2 mm |
Inside diameter | 25.65 - 26.15 mm | 20.41 - 20.91 mm |
Maximum out-of-plumb from either end | 2.0 mm | 1.65 mm |
Color | Green | None |
30A06 - VALVE SPRING SEAT | ||
Part number | 5203474 | 4484407 |
Material | MS-482 | MS-501A |
Thickness | 0.67 - 0.93 mm | 0.585 - 1.085 mm |
30A06 - VALVE SPRING RETAINER | ||
Part number | 5203578 | 4424033 |
Material | MS-3413 or MS-3414 Al killed | BS 970: 605M36, OPT 606M36 |
Hardness | HR 15N 82-85 | N/A |
30A06 - VALVE LOCK | ||
Part number - intake/exhaust | 4201349 / 5203577 | 4424035/ 4424034 |
Material | MS-3414 | N/A |
Number of beads - intake/exhaust | 1 / 4 | 1/3 |
30A06 - VALVE LASH ADJUSTER | ||
Part number - Stanadyne | 4105348 | N/A |
Body material | MS-3958 | |
Type | Hydraulic | |
Diameter | 15.900 - 15.913 mm | |
Dry lash | 0.62- 1.52 mm | |
Leak down | 5 -25 seconds | |
30A06 - ROCKER ARM | ||
Part number - Toledo Stamping | 4387269 | N/A |
- Welles Manufacturing | 4387270 | |
Fulcrum Ratio - base circle | 1.615:1 | |
- nose | 1.762:1 | |
Roller diameter | 17.75 - 17.80 mm | |
Hardness - valve tip pad & lash adj. socket | 50 RC minimum | |
Ear depth on valve tip pad - minimum | 1.5 mm | |
30A06 - ROCKER ARM WITH HYDRAULIC ELEMENT | ||
Part number - left / right hand assy - INA | N/A | 4484379 / 4484380 |
Shaft bore diameter | 21.00 - 21.02 mm | |
Roller width | 12.75 - 12.80 mm | |
Hydraulic element - bore diameter | 11.005 - 11.025 mm | |
- body diameter | 10.983 - 10.994 mm | |
30A06 - ROCKER SHAFT | ||
Intake / exhaust shaft -P/N | N/A | 4484373 / 4484419 |
...Intake / exhaust shaft -assy P/N | 4424011 / 4484424 | |
-diameter | 20.967 - 20.980 mm | |
...-end plug (2/shaft) P/N | 5203517 or 4556017 (7/16 in. ø) | |
...Intake shaft - end spacer - P/N | 4424061 | |
- end spacer thickness | 1.8 - 1.9 mm | |
30A06 - ROCKER SHAFT RETAINER | ||
Intake & exhaust shaft - P/N | N/A | 4424007 |
- length | 20.8 - 21.0 mm | |
Intake shaft end - P/N | N/A | 4424008 |
- length | 30.75 - 31.25 mm | |
Exhaust shaft end retainer - P/N | N/A | 4484423 |
- length | 23.75 - 24.25 mm | |
30A07 - WATER BOX & THERMOSTAT | ||
Choke thermostat-permanent bypass - P/N | 4105404, OPT:4387819 | |
Coolant temperature | 195° F | |
Connector - water outlet - P/N | 5281063 | 4442618 |
- gasket - P/N | 4179895 | 4442621 |
Water box assy - P/N | N/A | 4442998 |
- gasket - P/N | N/A | 4315333 |
30A07 - WATER PUMP | ||
Assembly - P/N | 4483451, OPT:4621171 | 4483451 |
Impeller diameter | 77 mm | |
Shaft & ball brg assy - P/N | 4621174 (w/4621171) | N/A |
Shaft & roller brg assy - P/N | 4483410 (w/4483451) | |
Gasket - pump assy inlet - P/N | 5203542 | |
- pump housing to body - P/N | 4387459 | |
Deflector assy - pump inlet - P/N | N/A | 4484321 |
Spacer - pump lower att to block - P/N | N/A | 4556247 |
30A08A - OIL PAN | ||
Assembly - P/N | 4448712 | 4448603 |
Capacity including filter | 4 quarts (3.8 liters) | |
Seal - front - P/N | 4387478 | |
- rear - P/N | 5203778 | |
Gasket - right - P/N | 4387475 | |
- left - P/N | 4387476 | |
30A08B - OIL PUMP | ||
Assembly - P/N | 4323626 | 4442298 |
Body - block pilot diameter | 36.02 - 36.06 mm | |
- rotor housing diameter | 63.017 - 63.094 mm | |
- rotor housing depth | 24.028 - 24.054 mm | |
- shaft bore diameter | 13.88 - 13.91 mm . | |
Rotor thickness | 23.978 -24.003 mm (0.944 - 0.9445 in.) | |
Outer rotor diameter | 62.763 - 62.840 mm | |
Shaft diameter | 13.85 - 13.86 mm | |
Gear - P/N | 5203105 | 4556215 |
- hardness | 229 - 286 HB | 248 - 286 HB |
- shaft bore diameter | 13.80 - 13.83 mm | |
- tooth flank surface finish - maximum | 2.0 um | 0.64 um |
Spring - pressure relief - P/N | 2402473 | |
- free length | Approx. 1.95 in. | |
30A08B - OIL SUCTION TUBE | ||
Assembly - P/N | 4387360 | 4387675 |
Seal to oil pump - P/N | 6032920 | |
30A10A -. INTAKE MANIFOLD | A515 2.2L HPTBI (EDF) | |
Assembly - no EGR - P/N | 4621027 | 4484413 |
- EGR - P/N | 4448618 | N/A |
Manifold material | MS-2418, OPT MS-2414F | |
Gasket (2 req�d) -P/N | N/A | 4484412 |
PCV nipple - P/N | 4343761 | 6034239 |
EGR cover plate -P/N | 3671447 | N/A |
EGR gasket - P/N | 4300297 | N/A |
30A103 - EXHAUST MANIFOLD | ||
Part number - assembly | 4621028, OPT 4273099 w/plug | 4484410 |
Manifold material | MS-3760B | MS-4062B |
Gasket - intake & exhaust - P/N | 5214650 | N/A |
- exhaust only - P/N | N/A | 4484411 |
30A113 - RIGHT ENGINE MOUNT | ||
Part number | 4556011 (US) or 4556013 (MEX) | 4442962 |
30B10C - AIR HEATER | ||
Part number | 5203338 | N/A |
30311 - OIL LEVEL INDICATOR & FILTER | ||
Part number -indicator | 4536071 | 4621111 |
...'tube assy | 4387575 | 4442916 |
...'tube bracket | N/A | 4442914 |
...-filter assy | (full flow type) | 5281090 |
30B12A - CRANKCASE VENT SYSTEM | ||
PCV (positive crankcase ventilation) valve - P/N | 4315405 | 3671076 |
TEE - 0.020 in. orifice - P/N | 4300267 | N/A |
Hose - PCV valve - P/N | 4315702 | N/A |
- TEE to intake manifold - P/N | 4315703 | N/A |
- PCV valve to cyl head cover - P/N | 4315704 | N/A |
- PCV valve to a/clnr - P/N | 4343477 | N/A |
- PCV valve to TEE - P/N | 4343851 | N/A |
- separator to cyl block. - P/N | N/A | 4621091 |
- PCV valve to intake manifold - P/N | N/A | 4621166 |
Adapter - PCV valve to oil separator - P/N | N/A | 4621020 |
Connector - adapter to a/clnr tube - P/N | N/A | 4621021 |
Tube assy - adapter to a/clnr - P/N | N/A | 4621022 |
Clip (front / rear) - tube to a/clnr support - P/N | N/A | 4621023 / 4621024 |
Oil separator assy / support bracket - P/N | N/A | 4621033 / 4621034 |
30C09 - TURBOCHARGER | ||
Type | N/A | Garrett TB0377 |
Assembly - P/N | 4484461 | |
Compressor housing | A/R: 0.52 | |
Turbine housing | A/R: 0.48 | |
Center housing | 180° watercooled jacket | |
Rotating assembly imbalance @ shaft speed - maximum | 1.0 G @ 60,000 RPM | |
Static actuator calibration, travel @ pressure | 0.015 in. @ 6.1 - 7.1 PSIG | |
Exhaust elbow - P/N | 5281143 | |
- material | MS-4062B | |
- nominal outlet diameter | 2.50 in. | |
Support bracket - P/N | 4484327 | |
Pipe - turbo compressed air to charge cooler - P/N | 4442856 | |
30C09 - TURBOCHARGER OIL PLUMBING | ||
Oil inlet -tube assy (5/16�) md. support clip - P/N | N/A | 4442846 |
...Oil return -tube - P/N | N/A | 4484085 |
...-hose - P/N | N/A | 4105457 |
-gasket - P/N | N/A | 4227980 |
-tube in cyl block - P/N | N/A | 4105456 |
-hose insulator - P/N | N/A | 5281164 |
30C09 - TURBOCHARGER COOLANT PLUMBING | ||
Coolant inlet - tube assembly (3/8�) - P/N | N/A | 4442839 |
- support bracket - P/N | N/A | 4442850 |
Coolant return - tube assembly (3/8�) - P/N | N/A | 4442842 |
