The Chrysler 300C SRT-8
300C | 300 Review | Other LX Cars / LX Overview
Preliminary performance for the 300C SRT-8 are 0-60 mph in the low 5-second range; quarter-mile time in the high 13-second range; and 0-100-0 in the mid-16 second range. The SRT-8 is due in Spring 2005, and will retain the 425 horsepower specification, with a $39,995 price tag (plus $650 destination).
Land vehicle Vehicle Car Chrysler 300 Rim
In 2003, when the concept Chrysler SRT-8 was first shown to the public, it was introduced as having "over 400 horsepower." On August 13, 2004, the actual SRT-8 debuted with 425 horsepower, coming from a 6.1 liter Hemi powerplant. Both the power rating and engine size had been rumored for at least a year - though some sources insisted it would be 500 horsepower, Viper territory. Perhaps there's some reserve for the future; perhaps not. It does seem as though the team has pulled out the stops for this one.
SRT-8 is based on the standard SRT name given, confusingly enough,
to vehicles modified by the PVO Group - that's Performance Vehicle
Operations. SRT originally stood for "Street and Racing Technology" but
now stands for "Strip, Road, and Track" - similar to the old R/T
designation which seems to have been abandoned.
Land vehicle Vehicle Car Chrysler 300 Grille
The SRT-8 (available in January 2005) adds a full 85 horsepower to
the already-quick Chrysler 300C, with nearly another half-liter of
displacement in the performance-geared engine. Nearly half of all 300s
sold through the end of July 2004 were Hemi-equipped.
The new 6.1 liter Hemi engine
The 425 horsepower, normally aspirated (no supercharger) 6.1-liter Hemi matches the gross horsepower
rating of the 426 Hemi engine exactly, albeit with lower torque (420
versus 490 lb-ft). It seems to beat the Elephant Engine's net
horsepower, which has various sources have pegged at between 330 and
(again) 425. In short, the 6.1 Hemi is the closest any V8 has come to
the most successful stock racing V8 to come out of Detroit - and it
gets better gas (and oil) mileage.
The SRT group uses traditional HEMI engine cues such as an
orange-painted cylinder block and black valve covers. Greater power was
achieved by boring the cylinders (increasing their diameter) by 3.5 mm
each; they also increased the compression ratio from 9.6:1 to 10.3:1,
and made other changes as detailed below.
Engine breathing was increased with new high-flow cylinder heads, a
specially designed intake manifold, and exhaust "headers"
with individual tubes encased in a stainless steel shell, all unique to
the 6.1-liter Hemi. Larger diameter valves and reshaped cylinder
ports in the heads maximize air flow. The intake manifold was
designed with larger diameter runners for higher-speed tuning.
Exhaust is routed through a larger-diameter (2.75-inch vs. 2.5-inch)
exhaust system with 3.5-inch chrome tips.
Performance-oriented camshaft profiles were developed to balance
total vehicle requirements, allowing more air in and out of
cylinders. This increases performance and allows a higher top
engine speed, 6,200 revolutions per minute (rpm) rather than the stock
Hemi's 5,400 rpm. Intake and exhaust valve stems are hollow, and
the exhaust valve stems are filled with sodium to help dissipate heat
more efficiently.
The 6.1-liter Hemi V8 engine is further strengthened with
redesigned components, including a reinforced engine block with
increased coolant flow, forged steel crankshaft, high-strength
powdered-metal connecting rods, floating-pin pistons (cooled by oil
squirters), and an oil pan modified for reduced oil foaming.
More information on the SRT 6.1 Hemi is on our standard Hemi page.
Power is channeled through an A580 five-speed automatic
transmission with specially calibrated driver-selectable range
control. A heavy-duty four-flange prop shaft sends the torque
from the transmission to an upgraded differential and axles.
Chrysler 300C SRT-8 cars ride and handling
Chassis setup for the Chrysler 300C SRT-8 is aimed at all-around
performance with a number of enhancements, including tuned dampers,
specially tailored spring rates and suspension bushings and
larger-diameter anti-sway bars. New front and rear suspension
knuckles contribute to a ride height lowered one-half inch from the
Chrysler 300C. The Electronic Stability Program (ESP) has been
specially tuned for the SRT-8's performance handling
characteristics.
The Chrysler 300C SRT-8 connects with the road via a new wheel and
tire assembly consisting of 20-inch forged aluminum wheels shod with
high-performance Goodyear F1 three-season tires (four-season tires are
an available option) with asymmetrical tread. Tire dimensions are
a beefy 245/45/20 in the front, and 255/45/20 in the rear.
Braking
The braking system was specially designed to slow and stop the car
safely and predictably, while providing benchmark braking performance,
setting a new standard for sedans in its class.
All four wheels feature stout performance calipers developed
by Brembo and equipped with four pistons for even clamping
performance. Up front, the Chrysler 300C SRT-8 has 360 x 32mm
vented rotors, with 350 x 26mm vented rotors in the rear.
Chrysler 300C SRT8 interior
The SRT-8 offers power-adjustable sport seats up front that are
fitted with performance suede inserts (matched in the rear seats) which
hold the occupants during spirited driving. Seats are also
equipped with heat and memory functions that, when paired with the
adjustable pedal cluster, may be adjustable to every driver.
Steering wheel, shifter and door pulls are covered with
"technical" leather trim for more positive grip.
Other SRT-only trim includes special finishing on steering wheel, door
pulls, door trim and center stack.
Full instrumentation, including a 180 mph (300 kph) speedometer,
tachometer and temperature gauges ensure the driver can monitor crucial
functions.
Premium amenities include a standard stereo with six-disc CD changer
powering a seven-speaker Boston Acoustics speaker system, with steering
wheel-mounted controls. Also available are Satellite Radio, which
offers hundreds of channels, and a hands-free communications system
with Bluetooth™ technology.
Heating and cooling adjustments are via an automatic temperature
control system with dual-zone controls and infrared temperature
sensing. Other standard features of the Chrysler 300C SRT-8
include an electronic vehicle information center with 128
customer-programmable features.
The Chrysler 300C SRT-8 interior is offered in a Light Graystone/Dark Slate color scheme.
Exterior
Modified front and rear fascias help direct air flow, particularly
through unique ducts that help cool the brakes. In addition, a
specially designed rear deck spoiler, while refined in appearance, is
also functional - increasing rear downforce by 39 percent without
increasing drag.
Other unique touches to the Chrysler 300C SRT-8's exterior
include body-color front and rear bumper inserts, body-color grille
insert with chrome collar, body-color mirrors and door handles, and
unique SRT badging.
Two exterior colors are available: silver and black.
Safety and Security Features
In addition to standard 300C features, the SRT-8 has standard high-intensity discharge lighting and rear parking assist.
Chrysler 300C SRT8 car specifications
Dimensions are in inches (millimeters) unless otherwise noted. We
are not reproducing items which are likely to be identical to the 300C,
whose specs are here.
ENGINE: 6.1-LITER, HEMI® V-8
Displacement
370 cu. in. (6059 cu. cm)
Bore x Stroke
4.06 x 3.58 (103.0 x 90.9)
Compression Ratio
10.3:1
Power (estimated SAE net)
425 bhp (318 kW) @ 6200 rpm, (69.8 bhp/L)
Torque (estimated SAE Net)
420 lb.-ft. (310 N•m) @ 4800 rpm
Max. Engine Speed
6400 rpm (electronically limited)
Fuel Requirement
91 octane (R+M)/2 recommended (premium)
Oil Capacity
7 qt. (6.6L)
Coolant Capacity
14.00 qt. (13.25L)
Max. Gross Trailer Weight
not rated for trailer tow
EPA Fuel Economy (mpg City/Hwy)
14 city, 19 highway, 18.4 combined
(note: no multiple-displacement system!)
TRANSMISSION: W5A580 FIVE-SPEED AUTOMATIC
1st
3.59
2nd
2.19
3rd
1.41
4th
1.00
5th
0.83
Reverse
3.17
Final Drive Ratio
3.06
Overall Top Gear
2.54
ELECTRICAL SYSTEM
Alternator and battery
160-amp alternator; H7 Case battery, 730 CCA, maintenance-free
DIMENSIONS AND CAPACITIES(a)
Ground Clearance
5.1 (130)
Drag Coefficient
0.355
Curb Weight, lb. (kg)-Est.
4160 (1888)
Weight Dist., F/R
55/45
SUSPENSION
Front
Independent SLA with high upper "A" arm, lateral and
diagonal lower links with dual ball joint front knuckle, coil spring
over gas-charged shock absorbers and revised stabilizer bar lower
"A" arm.
Rear
Five-link independent with coil springs, gas-charged shock
absorbers and isolated suspension cradle. Revised rear stabilizer bar.
STEERING
Type
Rack and pinion with hydraulic power assist
Overall Ratio
16.1:1
Turning Diameter (curb-to-curb)
38.9 ft. (11.9 m)
Steering Turns (lock-to-lock)
2.75
TIRES
Size and type
P245/45R20 - Front; P255/45R20 - Rear
Mfr. and model
3 Season Goodyear F1 Supercar
Revs per mile (km)
729 (452) Front , 720 (447) Rear
Optional tires
Same size, lower performance: 4 Season Goodyear RS-A
Wheels
Forged Polished Aluminum, 20 x 9 in.
BRAKES
Front
Rotor size and type
14.2 x 1.26 ( 360 x 32.0 ) vented
Caliper size and type
1.73 (44) Brembo 4-piston fixed with aluminum housing
Swept area
351 sq. in. (2261 sq. cm)
Rear
Rotor size and type
13.8 x 1.10 (350 x 28) vented
1.26 (32) Brembo 4-piston fixed with aluminum housing
Swept area
316 sq. in. (2036 sq. cm)
Std. on 300C SRT-8
8x9 (203 x 229) active tandem-diaphragm vacuum booster
Do you have an SRT-8? If so, register it here at Allpar and then at the SRT registry!
