1 - 9 of 9 Posts
· Registered
I replace the timing belt on my daughters 2007 touring edition 102,000, at a reputalbe shop in Hartford CT. Soon after my daughter came for a visit and I figured I would check under the hood. Alls well except that the anti-freeze level was not showing in the little white tak on the firewall. I had to add about half a gallon of anti-freeze.
I figured that the mechanic just did not fill it right or maybe the engine had to be burped and he did not do it. She has scince had to add a little more anti-freeze but does not see any on the ground and the car is not running hot.
I am not familiar with the correct procedure to replace the anti-freeze. Did the mechanic do something wrong or do I have a cooling leak problem?
Any advice would be helpful.
· Super Moderator
Does the cooling system have to be opened to change this timing belt? Or is the water pump driven from it, and replaced as a precaution at the same time?
· Registered
Yes, the water pump is usually changed as part of this as the timing belt drives the pump. My guess is the mechanic did not properly fill the system; especially if there are no signs of leakage. It can be a bit of a challenge getting the water pump gasket right given there is such little room to work. However, I would think that link would be fairly obvious.
· Premium Member
Rule of thumb is to change belt, idler, tensioner and the water pump. So the last time I dived into my 2.4l neon for a belt job it took several drive cycles to get the coolant level correct. It puked twice after I finally put more in the "white tank" than needed.
· Premium Member
I found the PT Cruiser 2.4 to be very easy to fill. I simply filled at the radiator, started her up, topped it off just a hair, then filled the tank to the hot level, never had an issue whatsoever, almost the easiest one I ever did. Check the tightness of the hose clamps all around, shouldn't have been touched to change the pump itself, but you never know. Stock ones are the squeeze clamps, just make sure they are intact and look to see if any of them were moved. Also, turn the heater on full blast, sometimes when they drain the heater core becomes an air bubble and very slowly it empties of air, usually it only takes a couple minutes of full flow to purge it.
· Registered
Discussion Starter · #6 ·
I had a proper job done, timing belt, idler , water pump. I have a Lincoln and if you change the anti-freeze there is a plug on a crossover pipe that has to be removed to burp the engine or you cannot fill correctly with anti-freeze. I was wondering what the prper fill procedure was.
· Registered
Normally, you are right. the thermostat that came with my PT originally, had a "bleed hole" in it that allowed air to escape. However, the replacemnent thermostat did not have that hole, so I needed to open the bleed valve right below the thermostat housing to let air escape while adding coolant. Still very easy, but if that valve isn't open, and the thermostat doesn't have the bleed hole, you may end up with an air bubble stuck in there.
· Premium Member
One reason I always drill a 1/8th inch hole in every thermostat I install. Enough of a hole to allow auto bleeding (you can hear air come out of it when filling it the first time), but always allows a little bit of pressure under the thermostat to pass without compromising the warming of the engine.
Reactions: The Wild One
· Registered
That is a great idea. I wish I had thought of that when I installed the new thermostat.
1 - 9 of 9 Posts
