At stock ride height, they will likely rub because they are too tall (especially up front). Width isn't too much of a problem.
You could crank the torsion bar adjustments up front to raise it to avoid rubbing, but then you need an alignment afterwards. But it will look, in my opinion, wrong because the tires are just too big.
The stock tire size was 205-75-15, the police version used 215-70-15.
