Torque specifications for fasteners
A bolt of the same size, thread, and material in a given grade can generally be tightened to a given torque; for example, grade-5, 1/4-20 should be torqued no more than 7 ft-lb in cast iron or 6 ft-lb in aluminum. In grade 8, those numbers are 11 and 9. This should apply universally to all such bolts, with some exceptions, e.g. for different alloys.
This information is for the bolt shaft size, not the bolt head size. Bolt and fastened material alloys change these numbers.
These numbers are for reference only; compare them to the bolt maker's specifications for confirmation. We suggest using them as a guide when you cannot obtain the car manufacturer's or bolt maker's specifications.
Metric Class
4T
Dia Pitch
Standard
Hex-head Bolt
Flange-Headed Bolt
mm mm N•m Ft-lb N•m Ft-lb
6
1
55 kgf-cm 48 in-lb 60 kgf-cm 52 in-lb
8
1.25
130 kgf-cm 108 in-lb 145 kgf-cm
10
10
1.25
26
19
29
21
12
1.25
47
35
53
39
14
1.5
74
55
84
61
16
1.5
115
83
Metric Class
5T
Dia Pitch
Standard
Hex-head Bolt
Flange-Headed Bolt
6
1
65 kgf-cm 56 in-lb 75 kgf-cm 65 in-lb
8
1.25
160 kgf-cm
12
175 kgf-cm
13
10
1.25
32
24
36
26
12
1.25
59
43
65
48
14
1.5
91
67
100
76
16
1.5
140
101
Metric Class
6T
Dia Pitch
Standard
Hex-head Bolt
Flange-Headed Bolt
6
1
80 kgf-cm 69 in-lb 90 kgf-cm 78 in-lb
8
1.25
19
14
21
15
10
1.25
39
29
44
32
12
1.25
71
53
80
90
14
1.5
110
80
125
90
16
1.5
170
127
Metric Class
7T
Dia Pitch
Standard
Hex-head Bolt
Flange-Headed Bolt
6
1
110 kgf-cm 96 in-lb 120 kgf-cm 108 in-lb
8
1.25
25
19
28
21
10
1.25
52
38
58
43
12
1.25
95
70
105
76
14
1.5
145
108
165
123
16
1.5
230
166
Metric Class
8T
Dia Pitch
Standard
Hex-head Bolt
Flange-Headed Bolt
8
1.25
29
22
33
24
10
1.25
61
45
68
50
12
1.25
110
80
120
90
Metric Class
9T
Dia Pitch
Standard
Hex-head Bolt
Flange-Headed Bolt
8
1.25
34
25
37
27
10
1.25
70
51
78
57
12
1.25
125
94
140
105
Metric Class
10T
Dia Pitch
Standard
Hex-head Bolt
Flange-Headed Bolt
8
1.25
38
28
42
31
10
1.25
78
58
88
64
12
1.25
140
105
155
116
Metric Class
11T
Dia Pitch
Standard
Hex-head Bolt
Flange-Headed Bolt
8
1.25
42
31
47
35
10
1.25
87
64
97
72
12
1.25
155
116
175
130
Metric Grade
9.8
Dia
Cast Iron
Aluminum
mmN•mFt-lbN•mFt-lb
69574
7149117
825181814
1040303025
1270555540
14115859065
16180130140100
18230170180135
Metric Grade
10.9
Dia
Cast Iron
Aluminum
mmN•mFt-lbN•mFt-lb
6149117
718141411
832232518
1060454535
12105758060
1416012012595
16240175190135
18320240250185
Metric Grade
12.9
Dia
Cast Iron
Aluminum
mmN•mFt-lbN•mFt-lb
6149117
725181814
836272521
1070505540
121259510075
14195145150110
16290210220165
18400290310230
SAE Grade 5
SAE Grade 8
Size
Cast Iron
Aluminum
Size
Cast Iron
Aluminum
Dia - tpi
N•m
Ft-lb
N•m
Ft-lb
Dia - tpi
N•m
Ft-lb
N•m
Ft-lb
1/4 -
20
9786
1/4 -
20
1511129
1/4 -
28
12997
1/4 -
28
18131410
5/16 - 1820151612
5/16 - 1830222418
5/16 - 2423171914
5/16 - 2433242519
3/8 - 1640302520
3/8 - 1655404030
3/8 - 2440303525
3/8 - 2460454535
7/16 - 1460454535
7/16 - 1490656550
7/16 - 2065505540
7/16 - 2095707555
1/2 -
13
95707555
1/2 -
13
1309510075
1/2 -
20
100758060
1/2 -
20
15011012090
9/16 - 1213510011080
9/16 - 12190140150110
9/16 - 1815011011585
9/16 - 18210155170125
5/8 - 11180135150110
5/8 - 11255190205150
5/8 - 18210155160120
5/8 - 18290215230170
3/4 -
10
325240255190
3/4 -
10
460340365270
3/4 -
16
365270285210
3/4 -
16
515380410300
7/8 - 9480360380280
7/8 - 9745550600440
7/8 - 14530390420310
7/8 - 14825610660490
1 - 8720530570420
1 - 81100820890660
1 - 14800590650480
1 - 141200890960710
