1 - 3 of 3 Posts
I want to tow a light trailer , less than 900 lbs empty, with my '06 Touring, auto transmission. I have installed a Curt class 1 hitch which has a tongue weight of 150 lbs. Total loaded weight will be about 1200 lbs.
Does anyone have experience with towing a trailer using this kind of setup?
the max towing capacity of this car is 1,000 lbs, so it can be risky little bit, but if the road is flat and fine so i would say you can try if it works fine so you can carry on the towing, i am towing truck driver at rite way towing currently driving as a blocked driveway towing Queens. share your experience if you have towed.
Towing 1200 Lb.s on a flat bed is no problem, on small vehicles it’s frontal ares you need to worry about. An enclosed box trailer will be hard on your P/T. A flat trailer should be fine on good roads.
1 - 3 of 3 Posts
