Hi,
Need a bit of directions here.
1997 Voyager 2.4
Trans was slipping. After checking the transmission and radiator fluid it was found that both fluids are milky brown.
The OIL is fine and probably not a head gasket issue. I’m assuming it’s a bad transmission “cooler”.
What do you think the issue is and what the best solution to fix?
Thx and any help would BE GREAT!
JAG
1997 Voyager 2.4
JAG
