I'd like to do a transmission "flush" after I drop the pan and change the filter on a 2001 PT Cruiser. This is where you pull the "supply" line from the radiator, run the car for a few minutes to pump out some of the old fluid while pouring new fluid in. I looked under the car and saw where the transmission lines go into the radiator. However, does anyone know which one is the "supply" and which one is the "return"? According to my info, I want to utilize the supply line in order to do this flush.
Thanks...
Thanks...
