1997 Plymouth Voyager 2.4 ltr 135,000 miles 3 speed transmission
About 5 months ago my radiator transmissioncooler busted open mixing the antifreeze with the transmission fluid. So I
replaced the radiator and flushed out the Transmission and torque converter.
Afterwards the Transmission shifted like new and had no issues until today.
.While driving, the Trans was slipping a bit then completely went out of gear and had the van towed home.
Keep in mind that if I let the Van cool down a bit it would go into all gears with no issues. But when the Trans if warmed up, NO gears including parking gear won't t work.
. The fluid is fine. I check the radiator fluid and that’s fine as far as a damaged cooler again.
Do you think the transmission is SHOT (I HOPE NOT) or could it be the speed sensors I’ve been reading about or could it be another problem.
Again, the transmission was running beautiful and like new for months.
Any suggestion would be great.
Thank you!!
JAG
Thank you!!
JAG
