2001 ram 1500 sport. Check engine light came on and the next day the Trans temp light came on and over drive turned off. Now I lost every gear except first and reverse after I did a Trans flush. After the long drive home in first gear I looked under the hood and there was Trans fluid on the frame looking like it came off the cooling line and there was hardly any fluid on the dipstick also and I'm guessing that there is a clog somewhere and is causing the Trans to over heat due to lack of flow and and a build up of pressure that caused fluid to leak out of the line on the bottom of the radiator... What do you think? And how can I fix this?
