Within the past few days I was asked by a family member to inspect a used vehicle for possible purchase. Vehicle is 2010 Chevy Colorado truck with 3.7 liter 5 cylinder engine and automatic transmission. Odometer indicates 149,159 miles.
After inspecting the body and undercarriage and interior I turned attention to looking at scan tool data parameters as engine idled. Engine at full operating temperature of 190 deg F. No current or historical diagnostic codes in the ECU (engine control unit). Upstream oxygen sensor was oscillating between rich and lean condition as expected. Downstream oxygen sensor was oscillating but at a much slower rate than the upstream sensor. So the oxygen sensors were working as expected.
There was no engine misfire and under rapid throttle acceleration no clouds of blue smoke emanated from the rear of the vehicle. So that seemed to be a good indication on health of the engine. The engine starts and runs well.
The short term fuel trim was oscillating between - 0.5% to - 2.0% and + 0.6% to + 2.0% fairly quickly so that was satisfactory. The long term fuel trim was set at + 12.3% and I could not get it to change to a lower setting by accelerating the engine. I am not an expert in understanding fuel trim values and associated implications, but from many auto maintenance videos it seems that any fuel trim value greater than a +- 10% indicates a potential problem?
So the ECU thinks the air - fuel mixture is a little too lean so it must add fuel to correct to bring it into stoichiometric balance at + 12.3%. Is engine wear at 149,159 miles the cause for the long term fuel trim to be excessively high? I do not believe the engine has a intake manifold leak as this would dilute the air - fuel mixture towards a lean condition and the short term fuel trim would tend to stay positive (not oscillate around zero) and add more fuel to compensate.
I wonder if a dirty throttle body or mass airflow sensor (MAF) could under report the amount of air entering the engine. This would cause the ECU to increase the pulse width on the injectors and add more fuel and after some time cause the long term fuel trim to go above + 10% consistently? Just looking for discussion / ideas or if there is something that I may have missed or misinterpreted. At this point I do not believe the excessively high long term fuel trim is a "no go" for purchase but something that needs to be kept in mind.
