Okay, so i'm getting near the 120,000 mile mark (just changed my oil at 114,000-ish miles) on my 01 automatic with the V6. I don't know what all has been done with the vehicle in terms of maintenance other than oil changes. Based on how the oil always comes out smoothly and is never that bad I'm guessing the previous owners managed to change the oil fairly regularly and has little to no sludge build up.
I was wondering what all I should do in terms of a tune up. I was thinking the timing chain should probably be changed, even though the 3.0L isn't an interference motor (at least my research says so). At the same time, water pump might as well be changed up. Flush the radiator if I can, it's a good idea since I live in the northeast...it's rather humid up here most of the year and rust is a bit of an issue with cars that sit. Last I checked the spark plugs they didn't look too bad, but I think I'm going to be changing the spark plugs as well as the distributor rotor and spark plug wires (I didn't know it was a distributor run motor till I looked more closely and noticed there really aren't any coil packs on the spark plugs and looked it up online as well to confirm).
I heard someone saying that at the kind of milage it may be a good idea to change the valve cover gaskets, should I do so? As well as what I'm planning on doing what else do you guys think I should do in terms of changing out stuff? I'll probably try and change my fuel filter (never a bad idea) as well, shouldn't be pricy to change either.
I'm just asking what all I should do since I honestly don't know all that much about newer vehicles, as well as that I do know that getting that whole intake unit for the 3.0L isn't exactly quick and easy and would know what all I should do maintenance wise while I have it off and can get to everything easier.
Does the Sebring have a filter on the AC? I don't know if mine does or not, I've never bothered looking into it. Thanks in advance.
