21 - 30 of 30 Posts
That would be 9.3K ohms, which is good.
So, going back over the posts, I don't see that any recent tuneup was mentioned. If you haven't done the wires, cap, ignition rotor and spark plugs in the last 30K miles, they should be checked and probably replaced.
Reactions: chuzz
Discussion Starter · #27 ·
Discussion Starter · #28 ·
Bob I cant thanku enough. I now have Redbone running, after 6mos. I changed out the starter relay, I then got spark too, #1 plug, then I set the gap on thepick up coil, as told. I then found TDC and set the timing. A little starting fluid, and she fired off.
Excellent! Enjoy!
I forgot to recommend this for occasional use:
80226
Reactions: chuzz
21 - 30 of 30 Posts
