The only place I have applied grease was where the brake pads slide in the pad bracket. Otherwise, I don't recall applying grease to the caliper pins. It's been a while since I actually serviced the brakes - the last few times I have had a shop do the work. I just didn't have the time to do it myself.
Please post how it goes. I have a 2016 Toyota RAV4 AWD and I suspect the front brakes will need service soon. It has over 91K miles on it now and I can feel a light vibration when braking. I suspect the rotors are slightly warped. Safety inspection is due in January, so I'll need to service it in the next month or so.
When I had it serviced (oil change/tire rotation), Firestone indicated all brake pads were at 10 mm thickness.
