Vacuum line stalling engine when connected to nvld
3433 Views 48 Replies 5 Participants Last post by  Bob Lincoln
Does anyone know why when I connect the 2 vacuum lines 1 from plenum the other on to of throttle body the engine cuts off on idle.
Do these lines go to a vacuum pump? Defective?
1 - 20 of 49 Posts
Welcome to Allpar. Year? N/A or turbo?
Can you post an image? Where do these hoses go to?
Reactions: 1
. . . Does anyone know why when I connect the 2 vacuum lines 1 from plenum the other on to of throttle body the engine cuts off on idle. Do these lines go to a vacuum pump Defective? . . . .
As ImperialCrown stated we need to know specific make, model, year and engine configuarion, 4 cylinger, V6, V8, and some images of the vacuum lines in question to make a reasonable, accurate diagnosis.
Now if you wanted a "wild guess" I would say one of the suspect vacuum lines might be connected to the EGR valve. Fully activated EGR (exhaust gas recirculation) will stall an engine and stop it from idling. But again just a guess. Give more detailed information as requested.
Reactions: 1
Sorry I forgot it's the base model, non turbo 2003, it seems it goes to a vacuum pump, in a real awkward place below the breaker booster, I'm hoping it's not the pump. I did an engine swap, on a car that was not running.
I also came across a relay,/fuse yellow and orange in color, 3, pins that fell off and I cannot find where that plugs into, wondering if that had something to do with it
I did change the egr valve, since the old one was broken, can I deactivate it
I'm not seeing a vacuum pump on that model. Is there an underhood vacuum label that you can use to identify the part?
May look something like this:
I would not run without an EGR valve if it is equipped for one.
The fuses & relays should all be in the PDC, unless someone added an in-line fuse for an accessory?
The PDC lid should identify the fuse/relay positions.
Pictures would help a lot.
Ufortunately some of the drawings in a factory service manual are mislabeled. In post #6 presented by ImperialCrown the trapezoid symbol that is labeled 2.7L would make you think that symbol represents the engine. It should be labeled as the vapor canister. See attached image.
Rectangle Font Parallel Schematic Auto part
. . . .the "pump" he is talking about is the NVLD pump and it's below the master . . . .
The device that provides pumping action and applies a vacuum to the fuel tank and evaporative system is the purge solenoid that is mounted under the power brake booster. The NVLD device vents over pressure, cleansed air to the atmosphere and seals the tank under a vacuum. It is located along with the vapor canister at the fuel tank.
Does this control the vacuum pressure
This is a 2003, I don't think it has an egr valve, just pcv valve
The vacuum houses go to this device, right?
No, it does not.
The 2003 does not have egr valve?
There are 2 lines, one goes to look like the cruise control and the other, to nvld looks like
Standard 4 cylinder stalls on idle when pvc valve hose connected to plenum or the vacuum line on top of throttle body. Disconnecting either one did not stall.
This car does not have egr valve, seems the 2 vacuum hoses, one back of plenum and other on top of throttle body, goes back to the fuel line and the nvld canister.
Does anyone have ideas
There should be a vacuum diagram under the hood of the car. Use it to check where hoses go.
Have you checked the underhood vacuum diagram?
. . . . .Standard 4 cylinder stalls on idle when pvc valve hose connected to plenum or the vacuum line on top of throttle body. Disconnecting either one did not stall.
This car does not have egr valve, seems the 2 vacuum hoses, one back of plenum and other on top of throttle body, goes back to the fuel line and the nvld canister. Does anyone have ideas . . . .
It is difficult to envision the dislodged. vacuum hoses on your vehicle without an image. If you can take a picture and post that would be helpful. Otherwise find the underhood vacuum diagram and connect lines as shown.
From a view into the engine compartment all you will see is the purge valve under the brake booster. There will be a vacuum hose from the purge valve that connects to a line under the body that runs to the vapor canister mounted on the fuel tank. The purge valve will have another port with a vacuum line that attaches somewhere on the intake plenum.
Follow the larger hose from the brake booster to the intake system. At the intake is there an open port with no vacuum hose attached? If YES this port with missing hose should have to be connected to the purge valve.
This connected vacuum line should agree with the underhood diagram. If the engine stalls at idle with this configuration, it is possible that the purge valve is stuck open. With a stuck open valve the engine is drawing in rich fuel vapors and the overly rich air-fuel ratio is causing engine stall. Just a guess on my part.
No hoses are missing, ask the hoses are connected you the correct ports , how can I test the purge valve
. . . No hoses are missing, ask the hoses are connected you the correct ports , how can I test the purge valve . . . .
Start engine and let it idle. Remove vacuum hose connected to vapor canister port on purge solenoid valve. Apply piece of paper to uncovered port on valve. There should be no vacuum at port trying to attract paper with engine idling. If vacuum is found, the purge valve is leaking and needs to be replaced. See attached image.
Font Camera accessory Machine Auto part Engineering
1 - 20 of 49 Posts
