The 1.4T in the Abarth responds well to an exhaust change. I was surprised it spiked than dropped down quite a bit. I'd be happier if it held 15-17 solid instead of bouncing aroundThat didn't sound too healthy, really. Besides that, I wonder if the pressure actually went above 20psi given it pegged and stopped. I would say one of the first bolt-ons would be larger diameter exhaust (that's what the bad sound is, restrictive exhaust).
That is a weak wastegate spring. The SRT-4 Neons did the same thing with the stock wastegate. Considering that its not a performance model I am not surprised.The 1.4T in the Abarth responds well to an exhaust change. I was surprised it spiked than dropped down quite a bit. I'd be happier if it held 15-17 solid instead of bouncing around
Mike
The SRT4 neon did not spike like that... It is a combination of things though, not just a weak spring.That is a weak wastegate spring. The SRT-4 Neons did the same thing with the stock wastegate. Considering that its not a performance model I am not surprised.
Quick to build pressure then they run out of breathe.I'm running the stock spring on my SRT4 and not a problem but tiny turbos can only blow so much.
