1 - 18 of 18 Posts
In or around California, looking for a 4 door Belvedere, Savoy or Plaza in decent shape. v8 preferred also hard top preferred but not a huge deal.
Discussion Starter #4
Also if I were to find a 2 door that was nice enough I would take that as well, looking for around 2-4k price range
I did like the Exner styling. I believe that the Fury/Belvedere were a 2 or 4-dr hardtop and the Savoy/Plaza were 2 or 4-dr sedans/wagons.
The B-pillar did strengthen the body structure. Hardtop glass seals were also prone to wind noise/water leaks.
Discussion Starter #6
they have rare instances of savoy and I believe plaza 4 door hard tops as well, the definitely also had 2 door ones as I've seen hard top 2 door savoys.
Note that 1955 and 56 Mopars; within the same division, were quite similar. 1957 ushered in the huge series of changes between the Torsion bar front suspension, ball joints, and first year of the 3 spd TorqueFlite tranny, etc.
You'll probably get a buildable 4 door for that price; two doors typically hold their value much better for whatever the reason may be.
Reactions: Branded209
Discussion Starter #11
If I get a 4 door i'll be doing a custom sectioned and chopped hotrod, either a 340 or 440 with a 6-71 and 4 speed driver, if it's a 2 door basically the same without the chop
Discussion Starter #13
they aren't better both have their strong points the 360s are just a lot cheaper to build, and I already have the 340 block. Mind you I have a built 360 with 340 race heads in my 72 and it's a great motor but definitely not better.
Got parts?
The cheapest I see nearby is a SW in Waco for $7900. You might look in junkyards that have vehicles that old. Craigslist hasn't been much of a site since they started charging $5 per car ad last year. Maybe Facebook marketplace will give you better results.
Discussion Starter #16
I'm not looking for a junkyard car I'm looking for a driver, I've been watching fb, craigslist and a couple phone apps as well
1 - 18 of 18 Posts
