1 - 2 of 2 Posts
Must be am fm.
I think the number is 366.
Rebuilt or perfect preferred but a core might work if its clean and can be rebuilt.
If you are a rebuilder and have parts etc. it would probably be prudent to replace the speakers as well.
Discussion Starter · #3 ·
Thanks for this,
I found that the stock am only had a dash speaker and car is not wired for rear spkrs.
I found a guy that installs a chip that will change over to fm by quickly turning the radio off and on again.
This will convert the tuner. A bit of channel searching on the wrong dial and then set three of the 5 push buttons to save three chosen channels. (three of the buttons will be converted to do this).
The good part is that its still original and looks absolutely stock.
1 - 2 of 2 Posts
