Hey all,
I might have found an acceptable two-post lift for use in my workshop, capable of lifting as much as 9000lb. Trouble is, I want/need to set it up to be able to lift my '82 Dodge Ram D350 crew cab short bed, which eventually I want to do the Cummins swap on.
Any information on front/rear weight distribution would be much appreciated, as that would dictate if this lift can be positioned properly in my garage. Even info on the '89-'93 club cab long bed diesels would help, as those are probably close enough to use for a comparison.
Thanks,
Thanks,
