What is the truth behind the 340
21903 Views 48 Replies 22 Participants Last post by  Scrounge
The power numbers they give the 340 are not that impessive but it has a great rep. Was Chrysler not telling the truth.
Whats the best way to compare A 70 nova with a HO350 vs a 70 Dart GT with the 340?
I would compare B bodys but aren't the B's a bit heavier then the Malibus?
Reactions: Shane Estabrooks
21 - 40 of 49 Posts
· Banned
Ya knowing what I know now.. It was just a 318 sb, but I think at that time my gearhead friend was saying that because of the "look" of the intake.
Wish I still had that car... so much fun was had. When I look back I've owned a lot of 318s .. wish I could say that I've had a 340.
I've heard lots of the 318 "Big block" and "wide block" terms growing up. I've really yet to figure out what they were talking about. The only thing I can figure is the 318A engine built up to 1966, which was the poly. I dunno if that's what they were referring to? Myself, I've only ever known the 318LA engines.
· Banned
I assume they’re referring to the older poly 318 also.
The 340 was a light weight powerhouse and combined with the lighter Duster made a great $3k street machine.
Dad tried a 360 2bbl in a 71 Sport Fury. It was a decent engine in a big car but just didn’t have the ooomph a 383 2bbl had. Plus the 360 used oil for some reason.
· Registered
The 318 poly was generally referred to as the "wide block 318". In fact, though, the A (poly) and LA (wedge) blocks (less heads and manifolds) were virtually identical in external size. The poly heads, though, were larger which made the complete engine look bigger.
As for the Chrysler B bodies and GM A bodies, both were in the intermediate market. Generally the Mopar models were on longer wheelbases than their GM opponents, and about 50 pounds lighter as well as a little more money.
A 1969 Malibu V8 had a 307 as standard, weighed 3,230 pounds and cost $2,690. Plymouth's Malibu competitor was the Satellite with a 318 V8 as standard. Weight came in at 3,156 and sold for $2,883.
· Banned
We had 318s in a 70 Coronet and 71 Satellite. The same years my uncle had a Monte Carlo then a Chevelle with 350 2bbls.
Being H.S. kids my cousin and i often "compared" acceleration of dads' cars. The 318s could match or beat the 350 off the line then he would pull ahead somewhere in second gear. Don't know what axles were in the cars but dad often ordered 318s with a quicker rear end.
· Super Moderator
· Premium Member
318 runs out of steam at about 4K rpm. 340 keeps pulling......
· Registered
Discussion Starter · #28 ·
I often posted here about the size and comfort of modern cars but even back in my high school days (early 70's) I loved the 68,69 Barracuda and darts. My dream car back the was a 69 barracuda with a 340. not only was it sporty but is was real cormfatable and it had a real trunk.
Much better car then the camaro or mustang.
· Registered
A 318 in an "A" body was a nice running car.
Don't know what they meant by "wide block".
318, 340 and 360 were small blocks based on the 273 since maybe the 67 model year..
The original 318 was A based; the 67 and newer were LA based. The A was visibly wider due to the heads (the BLOCK was the same width; there's actually folks that have retrofitted A heads to LA motors, either drilling the extra oil return paths in the block or using hoses and dumping the oil return into the oil pan).
See A series Chrysler small block V8 engines -277, 301, 303, 313, 318, and 326 (at https://www.allpar.com/mopar/a-engines.html ) .
RwP
· Valued Member
I had a 68 340 4 speed fastback and it would pull to 6K.
We would run power runs to 6000 rpm on the 340" but it peaked at 5600 rpm. We ran power runs to 4800 for the 318" but it peaked at 4400 rpm. We always ran the power runs at 400 rpm increments and would shut down when the power fell off at the next speed after the peak.
· Registered
2014 Ram 2500 HD 6.4 Hemi
One could always take a 360 or 318 .. work the heads and stroke it to a 340 but with that said my 95 318 with a few aftermarket goodies and on a budget was a very awesome engine.. good enough to paste 340 on the side if wanting too.
· Premium Member
The "problem" with the 318 is its small valves. If you change the heads to get bigger valves you loose compression so you have to change the pistons too which can lead too clearance problems. I left the stock heads on my 318 but ported the heads as well as doing a 3-angle valve job. Compression was bumped up to 9.5:1 so it has plenty of low end power, Also used an Edlebrock cam, Performer intake manifold and 4-bbl carb.
· Valued Member
If I remember correctly the 1971 and 1972, 340 and 360 engines were equipped with 3418915 heads, so-called "J" heads, because of the cast-in J in three locations (backwards in one place) on each head. These were either equipped with 1.88 inch/1.60 inch valves, or 2.02 inch/1.60 inch valves, and have "open" chambers with volumes of 65-73 cc.
Police sedans were equipped with a high performance 318 engine, which was equipped with 360 heads and a 4 barrel carburetor (Thermoquad through 1984, Quadrajet from 1985)??
· Registered
Eddie, thanks for your post #31. Peak power at 5600 is impressive. The early 340 [68 to 71] heads were known as 'X' heads. They had the 2.02" intake valves. The 'J' heads came out in 1970. Some with 2.02" , but most with 1.88" valves. Putting 2.02" or even 2.05" valves in the 'J' heads were commonly done back in the day. As you said, the cast crank limits the safe rpm level, so a wild cam is of little benefit. Head porting can give good results. A sensibly built 360 engine makes for a nice street engine.
21 - 40 of 49 Posts
