Anyone who's ever tried lining up the offset hole on an A727 or A904 can appreciate an RCH of difference in measurements.
To be sure, the Mopar rims are not the "same". There are a couple of TSB's floating around out there regarding transient vibration from improper mounting, sizes, etc ad nauseum.
To me, the higher the performance of the vehicle, the more it would seem proper to pay close attention to what you're doing.
Below is a link showing all of the various bolt patterns and hub registers, which does show the slight differences. The 2011+ LD/LA Chrysler hub is a full mm larger than the typical Ford hub size. In the overall scheme of things, especially considering wear, that may seem like a rounding error at best. But with vehicles capable of 140+ mph - even with a beat-up old police model,for example - it's not something to mess around with. Using a foreign size may work, to a certain degree, because of those tolerances. But what happens to those tolerances over time, especially with the additional wear induced by vibration? You will very likely experience excess wheel bearing wear, rotor run-out, reduced caliper clamping force, and bizarre steering behavior.
It's your vehicle, of course, so you do as you wish. Just make sure you have plenty of liability insurance.
Bolt-Pattern-and-Hub-Centric-Guide.pdf (uswheeladapters.com)
