Should be as follows:
Low beam operation - low beams only.
High beam operation - low and high beam lights on (all 4 headlights)
I should have been more precise. Yes, the outer most lights should be the only ones on when in low beam only operation.But do low beams = 4 lamps on or only the 2 outermost ?
High beam lamps do not have a low beam filament in them. I have seen some people convert their cars to having all four lamps on for low beam by replacing the high beam lamps with the low beam lamps because they also have a high beam filament in them.I should have been more precise. Yes, the outer most lights should be the only ones on when in low beam only operation.
That is not true. Just last night I had some fool in the left turn lane across the intersection from me with his high beams on and all four lamps were on. And this was a newer car with the composite head lamps.With the composite headlight system ( 93 and up ) only the inner ( high beams ) light when in high beam mode.
I have had a 92 and 93 Daytona, both have the aero style headlamps like the LeBaron. George W is right, low beam is the outer headlights only and high beam is the inner headlights only.That is not true. Just last night I had some fool in the left turn lane across the intersection from me with his high beams on and all four lamps were on. And this was a newer car with the composite head lamps.
True, but if I am interpreting George's post correctly, he's saying only the hi beam headlights illuminate when the hi beams are selected and the low beams turn off. Every 4 headlight system I've seen all 4 headlights are on when hi beams are selected. I just checked my '10 Journey and all 4 illuminate when I switch to hi beams.I have had a 92 and 93 Daytona, both have the aero style headlamps like the LeBaron. George W is right, low beam is the outer headlights only and high beam is the inner headlights only.
