Visual inspection is the cheapest and maybe best way. Check underhood along fuel lines, along the underside follow the fuel lines back to the tank; check the gas tank grommet at the filler pipe, and the filler pipe itself. Some of these have a rubber section to the filler pipe that can degrade. Check both with engine on and off, and with tank nearly full.
