1941 Plymouth Pickup Carburetor Question
4.6K views 6 replies 4 participants last post by  68RT
#1 ·
I've got a carter careburetor off a '41 plymouth truck I thought someone here might have some insight into. It's a carter ball and ball DTB1 carb, not original for this truck I don't believe. I think that particular model is for a dodge of the same/surrounding years.
My question is; when i took the carb off to clean I noticed the throttle goes completely open. Should this be the case? I can't believe it is, but it seems that it was being held closed by the linkage and a few springs.
But my thought was the springs were not supposed to be there, were added to hold it closed, and I would like to remove them if so. I can't see a specific reason why the carb is staying WOT on it's own and that's why I ask if the linkage on these trucks was actually supposed to hold it closed for any reason.
Thanks
1941 Plymouth PT 125
#2 ·
When you remove the carb from the vehicle, you disconnect the springs that hold the throttle closed. Therefore, the throttle will flop wide open with the carb off the vehicle.
When installed, it MUST have the throttle return springs connected, or it will flop open with disastrous results.
#3 ·
I agree that you want an external throttle return spring for safety.
I believe that these carbs also had an offset throttle butterfly disc on the throttle shaft axis that would tend to close with air rushing past it into the engine. The slightly larger butterfly half would be towards the air horn.
#4 ·
Many years of Mopars with flatheads had that design. You lost the return spring and they went to full throttle. Wise to make sure the sling and connections were in good condition. Had it happen on the fifty Chrysler and dad on the 59 Plymouth. Both cases the engine was turned off and spring repaired.
#6 ·
Usually there were two return springs on older cars, at least in the 1960s and 70s. One was inside the other (concentric) in the applications I've seen. Redundancy.
