41 - 43 of 43 Posts
Sounds similar to an issue with the 2009-2011 Dodge Charger with a bad SKREEM module and door handles combining to keep the IOD active for long periods of time. I'll see if I can track the RRT down and PM you with it.
Hi there !
Tommorrow i have thw dreaded deealer appointment and your post is giving me a lot of hope after reading all the horror stories, my problem is very similar.
One day out of the blue the battery was dead, jumped it and went to a party..it started when we came back but the next morning ..battery dead again.
Jumped it again just to have it dead the next day.
Took it to a firestone a d they "tested" the battery and ofc they said it was bad..
$180.00 to replace it which i did.
The next day..you guessed it, battery dead.
So ill jump it tommorrow to be able to drive it to the dealer, and hopefully they will help me fix itn this vehicle is a 2012 dodge journey RT with only 49k miles on it.
Thanks for your imput !
Add Additional Ground Straps From the Negative Battery Terminal in the Engine Compartment to a Bolt from the Engine to the Trans and a Couple Places on the Body.
Use a Battery Terminal Size Wire on the Engine/Trans Bolt and #10 Wire on the Body Grounds.
The Fix Cured my Journey's Electrical Problems.
Also the 2010 Has a TSB Recall to Fix It.
owns 2023 Dodge Durango GT
41 - 43 of 43 Posts
