First and seeming to be most important currently is that the radiator fan is not working and causes the car to start to overheat when not moving, I’ve looked in to a lot of other people with the same problem and am going to give the fan, and its relays a look as soon as I have time. Secondly the car has engine surged a few times taking off from stop signs and one time while on the highway, I’ve only had the car a couple hundred miles so I’m not really sure how constant this is, the surge also lights up a engine light that goes away, it is the only engine light, but the problem is I can’t look at the light because the OBD II port isn’t giving any power, I’ve checked the fuse and swapped it out and that didn’t work, once I get time I’ll always be making sure the ground have a good connection as I’ve seen that in some of the research I’ve done on that too. And lastly the AC isn’t working, it doesn’t blow hot but it doesn’t get any colder than just turning the AC off.
Edit: it’s only surged 3 times total and each time only happened for a second and I just had to wait a second and I could drive off find again.
