21 - 40 of 67 Posts
Pulling off a super modern inline six would technically and profitabilitywise be a major product building acheivement. If V8's must go away then a charged inline six would be the next best thing. If the market stays like it is then having the most advanced six out there would also be quite a coup in Alfas, Dodge, Jeeps, even Rams and Maserati. How about a Chrysler 300 with a 400 hp inline six? A 600 horsepower Challenger SRT inline 3.6? How about diesel inline sixes for Ram and Wrangler.
Dave ZI know it's more complicated than “gee, there’s an empty space here” and that it’s very hard to do. But I also know the engineers are very very clever. I doubt the six would ever be used in something like the Compass, but it might work in something wide like the Pacifica. I do think the main goal is not mainstream cars but large cars and high end Jeeps and Rams and such.What if an inline six was the base engine for Chryslers?
JavelinAMXPower overlap in a six plays into smoothness and a somewhat more subtle power curve, especially compared to an I4.A hybrid setup can shut down the engine if it is in a non-optimal state and an electric motor beats the l6 on both counts.
V
Erik LatranyiIf FCA thinks FWD does not need the inline 6, they are, once again, not understanding the North American market.I suspect the i6 will be for north south orientation only. That doesn't necessarily eliminate fwd, but the lh cars were struggling with new crash standard previously and I suspect it would be a similar challenge now. Personally I think the pentastar will be the fwd 6 of choice for a long time
DAGARI suspect the i6 will be for north south orientation only. That doesn't necessarily eliminate fwd, but the lh cars were struggling with new crash standard previously and I suspect it would be a similar challenge now. Personally I think the pentastar will be the fwd 6 of choice for a long timeI'd imagine their i4 may be worthy of future v6 power targets. At least until all cars go electric. Instead of "get em while you can" for v8s, it will be for the I.c.e.
Should be heavier than a v6 due to a longer block and crank.
- on the other hand it has just one camdrive and the single longer head shoud be lighter than the 2 v6 heads.
- on the other is the fact that the inliner needs to have a stiffer block and crank, read heavier..
- on th...
Actually i know of no inliner thats considered compact, light and fuel efficient.
- ok the slant was actually quite a fuel sipper but thats it.
I can only se one use for a small inliner and that is for use in highend sedans were its considered exotic..rwd only.
I would not be surprised if it leaned a bit, really. But I WOULD be surprised if they called it a slant six.
That was a very durable engine but rarely particularly efficient “as produced” because they were cheap with the carb and such.
Dave ZI would not be surprised if it leaned a bit, really. But I WOULD be surprised if they called it a slant six.
That was a very durable engine but rarely particularly efficient “as produced” because they were cheap with the carb and such.What kind of power would you expect from this motor? The new 5 series straight T6 does 60 in 4.9. I know some will argue that BMW isn't a direct competitor but without getting into that do you expect that the Tornado will perform similarly?
I would assume a twin turbo version’s goal would be around 400 hp. I do not have that information. That's an assumption based on the ancient five year plan chart and people saying it's intended to replace the Hemi in most places. I suspect 380 hp would also be reasonable if the torque curve was good.
Dave ZI would assume a twin turbo version’s goal would be around 400 hp. I do not have that information. That's an assumption based on the ancient five year plan chart and people saying it's intended to replace the Hemi in most places. I suspect 380 hp would also be reasonable if the torque curve was good.All that low end torque will be nice.
What's the reasonable debut? 2022 or 2023? With FCA, many things can and probably will change by then. Until it's rolling down the line at whatever engine plant builds it, I'll believe it then. If they roll back mileage and emission standards further, the Hemi will continue I'd bet.
21 - 40 of 67 Posts
