I put this under this section because thought it would point out a sense of decision making within the company and how it can effect people that have been loyal and supportive.
The Prowler. Most know of the car but I sure quite a few don't know of the cars quirks. There are three problems that will develop with EVERY Prowler. Two are minor and correctable. The third can be a life altering event if a failure occurs and you are at speed.
First- At some time the speakers, usually the doors first, will have the foam ring deteriorate. It can be fixed or replaced. Second- The door window mechanisms. Part of the window raising plastic tubing will crack or outright fall apart. They can be fixed or replaced.
Third- Possible life threatening. The front steering lower a-arm ball joints. This is a BAD problem that many have experienced and all will at some time. The car as innovative as it is has a design problem that was not evident during it's initial design and showed itself in real world driving. Because of how the suspension controls road shock, the lower ball joints take a tremendous pounding. Depending on terrain and miles driven will to an extent determine the life of the ball joints. Here's what can(will) happen. First, the ball joint boot will tear at some point and if not caught at a reasonable time will allow the grease to become an abrasive and grind the internal stem and ball end to eventually tighten and at some point snap off. That's only the first part of the problem. Because of the pounding the joint takes regardless of the boot condition, the ball joint stem ball end, will pound clearance between the ball and housing that will at some time pop right out of the housing and disable the cars steering. The wheel at what ever speed your traveling, will tuck usually inward scraping the tire across the pavement with no steering control. The factory issued a TSB years back that specified the torn boots as the focal point of ball joint failure. Replacement ball joints were at the time" the fix". But all that did was to install a new ball joint and start the clock again because eventually the boots will fail again or if they don't the ball joint will stem will snap off or pull itself out of the housing as pointed out. Were starting to see failures from the TSB recalls done several years ago. And the boots are still in tact.
Ball joint recall kits have been available and installed as needed either from torn boots or clearance found in the joint before failure. At this point this possible life threatening problem will not be going away.
So I'm writing this to get your opinions on what FCA has now decided to do regarding the Prowler. Unfortunately the recall kits have been depleted. Recent communication with the company(FCA), has produced this answer as to when the kits will be back in stock. "They won't. At this time the company has no plans to re-stock these ball joint kits". There has been no other option at this point.
Since this can be a life threatening environment and I would assume that FCA knows this and has decided to ignore it, what do you think of their answer? Exceptable or not?? I think it's horrendous.
