So how hard is it to change the rear main seal on a 5.9 Magnum engine? It's in a 99 Dakota R/T. I had the oil changed and they pointed out it seems to be leaking as well as the PS fluid I already knew about. Assuming they are right, can the seal be changed with everything installed? Or do I need to separate the engine and transmission? They cleaned everything up so hopefully I'll be able to confirm or deny the oil leak and where it's coming from. I'd already planned to find and fix the PS leak.
My goal is not to have to park the truck over something to keep my garage floor clean.
