Hi Allpars,
New to working on a Slant 6, with limited mechanical ability. It's been running okay, not great, and here's what's going on now. (Slant 6 forum has been slow to bestow me a new log in, but Ive seen that some of those folks also frequent this board, like Slant Six Dan, who seems to really know his stuff)
Have a 74 Dart Swinger, pristine body & interior and a Slant 225 (with a/c and a a904 automatic) that was brought back to life a few years ago following a 25 year covered, garaged, nap. Mechanic dropped the fouled tank, replaced carb (installed a Holley 1920) cleared it the lines prior, changed oil, coolant, plugs, wire, distributor, and she fired up reasonably well. Drove it for about a year here on Cape Cod locally, as the 1920 carb would stall on me during left hand turns. Lol. I got creative in my travels.
Last year, replaced 1920 for a Holley 1945, which I read was original on a 74. Left hand turn prob was gone, and it ran pretty well for a year on local Sunday joyrides. Replaced water pump, alternator, radiator, master cylinder, brake hoses and similar incidental items just as proactive maintenance. All good.
This past summer (2021) ran great - but always had a bit of a bog upon sharp acceleration - (yes I know it's a 6, not an 8) but yet, it was drive able and enjoyable.
Early this fall, I drove it over to the next town, gaining confidence in its performance, when all of a sudden following an extended parked idle at a friends house, (30 mins) on the way home, it died upon acceleration at approx 40 mph. First sensation was a lack of response in acceleration, then just a total bog down, which resulted in a total stall. 5 minutes later after a few labored cranks, she drove me home (only about 1 mile) at low speed with no prob.
So... I replaced the coil, ballast resistor, ignition module, voltage regulator. Checked all wires and vacuum hoses to make sure connected. All were fine. (I dont know how to check actual vacuum readings, beyond my expertise for now) Tried car again. Fired car up, idle was uneven. Surged and retreated, but evened out. Tried driving on level road at speed. It died in the same manner, bog on acceleration once warm at about 30-40 mph. Restarts after about 5 mins, and I can limp home at slow speed.
Researched this, and replaced EGR valve with a NOS appropriate Mopar part. Old one had a bit of carbon, but seemed alright. No change. Same symptoms. When it stalled again under load in drive at 35 mph, I did hear a bit of a quiet backfire as it died on the road.
Convinced I'm looking at fuel now rather than electrical, I re calibrated carb settings (mix and idle) by setting screws and backing out 2 1/4 turns each on the Holley 1945. Figured it's drowning on fuel? It Idled perfectly, but after about 10 solid minutes of smooth idle in park, she just dies. Not a pronounced deterioration to idle, just a brief choppy span, and it deteriorates to a stall.. like a 15 sec death.
Idle does seem to have a very subtle "fart" to it, really hard to hear. At this point I'm imagining things. But... something is definitely wrong, and I'm guessing its fixable due to these symptoms, I just can't figure out what it is based on my limited expertise.
So... I'm thinking vacuum advance on distributor, or distributor pickup? Timing off? Fuel filer seems clear. Mechanical fuel pump? (Which was replaced at resurrection)
Btw, tranny seems to shift fine prior to under load death, hoping it isn't the tranny.
I'm bringing it to a mechanic, who is more experienced than I am, and I'm going to explain this same timeline of events to him. He has better tools than I do!
Thoughts...
a) this has to be something traceable, fuel wise. Electric choke? Pain in the [I should have my mouth washed out with soap for using such terms] emissions crap? Such as vac amplifier etc? (Osac has already been routed to bypass air cleaner housing straight to distributor)
b) heard the carter (or is it weber?) bbs is a better simple hassle free carb than the holley. Will a 300 dollar expenditure be worth it?
c) should i upgrade to a super six set up... clifford or aussie 2bbl intake with a carter (or is it weber bbd) running with stock exhaust for the hope of greater reliability? That's about 1k in parts when I'm done- plus linkage, as I'm in no position to hunt graveyards. (Btw, manifold head bolts all look clean.. and so this could be do able)
d) Eventually ( I know this is slant 6 blasphemy) drop a 360 crate in it, update the 904 tranny to a 727 and update the rear end 7.25 to an 8.25 sure grip posi. Sure, that would be more than nifty, but I'm also content to just have a reliable 6. Plus, it would cost the better part of 10k.
If this was your child, what would you do ?
Thanks!!
Gregg
Thoughts...
Thanks!!
Gregg
