Squealing from the Alternator, Alternator Bearings or Decoupler Pulley?
31K views 7 replies 6 participants last post by  chuzz
#1 ·
2002 Dodge Grand Caravan eL w/3.3L 41TE and 210k miles.
This year Mini-Van and many Chrysler products have a decoupler pulley on the alternator, a one way clutch to let the alternator overrun the motor, for less stress on the drive belt and tensioner. As I've been reading, these seldom last the life of the vehicle and often need replaced.
I've had a pretty noticeable squeal from the accessory drive belt of this vehicle. Replaced the Serpentine belt, it needed it. Reduced it some, but it was still there, more of a squeak than a squeal, it is definitely NOT a slipping belt.
Replaced the pulley wheel on the tensioner (it needed it) the aftermarket replacement was metal instead of OEM plastic and every so slightly larger in diameter (like an 1/8th of in), but it seems to be working fine.
The squeak is still there. And its NOT constant, nor is horribly bad, but its noticeable every few seconds there is a squeak. It seems loudest from the alternator area. I used a short broom stick to the different accessories to my ear, I'd be damned if that doesn't actually work, its a totally different sound, but sure enough its a sound you can tell if its normal or wrong. The alternator sounds is inconsistent, even gravelly but I don't think a squeak sound carries over the broomstick.
So, is there a way to tell if I need a new alternator or just a decoupler pulley?
From what little I gather, a bad Decoupler Pulley makes a rattling sound, NOT a squeak. But the decoupler pulley has a bearing in it as well as the alternator.
I did some of the tests for the Decoupler Pulley, and it looks like its bad.
Have a helper run the engine up to 2500rpm and turn off ignition at that rpm, the alternator should continue to spin, in my case it stops with the engine. Another sign of a bad decoupler is one that makes noise as the alternator continues to spin after the motor stops. With the belt off, I can turn the alternator pulley and try to turn it the opposite direction and the alternator turns with it (from what I gather that is NOT a valid test, a new Decoupler should work well enough that you should see some decoupling trying to turn the opposite directions quickly, but a worn but still good one will resist it more, you have to stick something in the fan of the alternator to put up some resistance.).
Here's the thing, if the alternator is bad, I don't want to pay for a new decoupler just to find out I wasted that money and have to buy a new alternator that will have a new decoupler pulley on it. Anyone have a better idea how to narrow this down to decoupler or alternator?
I think this an unrelated cause, because the PS pump sounded OC, but NOT as smooth as the water pump and AC clutch or tensioners, the idle tensioner was almost silent. On first start in a cold soaked vehicle, below freezing temps, twice we have noticed a sudden loss of PS boost when trying to turn the wheel to quickly, only for a second, and there is no associated belt squeal. It is likely internal hydraulic and related to the cold. Cause it goes away right away and doesn't come back. Heck it might just be cold fluid in an older weaker pump and rack.
#2 ·
Decouplers usually rattle or roar. Squeak is usually belt. If you spray a small amount of water on the belt, does it change or stop the squeak?
I believe that ATF+4 is the P/S fluid on these. Has it ever been flushed or changed?
#3 ·
The belt is brand new, I have NOT tried to spray water on it, or trouble shoot it further. Its possible a failing accessory is dragging and the squeak comes from an overloaded belt. The idle tensioner pulley seems in great shape, the tensioner arm seems strong and moves smoothly without noise (putting a breaker bar on it to pull the belt) the tensioner pulley is brand new. So the root cause has to be one of the accessories. It seems Decoupler Pulley on the Alternator has failed, but it has just turned itself into a solid pulley, the test where you rev up the motor and kill the ignition, it doesn't make a sound, but I can see the rotor inside the alternator stop with the motor.
The PS fluid has been flushed several times with ATF+4, but its probably been at least 3 years since it was last flushed. The once or twice we've lost PS boost, when the PS was very cold, there was no squeal or noise from the belt, so I'm pretty sure its a separate issue. I think the first step in trouble shooting the PS problem is probably flush and refill with fresh ATF+4.
#4 ·
Squealing from a new belt is usually one of two things - loose belt, or misaligned pulley. The pulley need only be out of the plane of the other pulleys by 1/8" to make noise. Look at any rubber isolators on the alternator, see if they have deteriorated or moved, and pry slightly on the alternator mounting to see if the noise changes.
#5 ·
Its NOT squealing with the new belt, its a squeak, sounds like bearing noise. Perhaps its a millisecond squeal here and there, but it really sounds like the accessory itself. It has an spring loaded tensioner and the alternator is bolted directly to the engine.
I haven't done a good comparison to see if the accessories are aligned, but they are all solid mounted with a spring tensioner on the belt, so getting out of alignment would mean internal failure in the component is allowing some of them to walk and cause the misalignment.
#8 ·
A bad decoupler pulley will make the engine sound pretty much like a diesel. Go to caliberforumz.com and do a search. There's a TON of post there about the bad decoupler/alternator and if what you're hearing is a squeak, it's not either one of those.
