Folks, look. The 413 was NEVER developed to be a racing engine in it's original form. It was designed to be a high torque, medium horsepower application to haul the Chrysler luxury barges around with a decent amount of aplomb.
In early 1962 when L. Townsend looked around to see what Chrysler had to put on the "street" the only big inch engine was the 413. The Petty racing clan had done LARGELY their own development work on the engine starting in 1960, no real assistance from Chrysler in that respect....... BUT, Chrysler did go so far as to make the engine available across the counter. Even with all the Petty learned applications for horsepower, it just wasn't enough!
The 413 cu in (6.8 L) RB was used from 1959 to 1965 in cars. During that period, it powered almost all Chrysler New Yorker and all Imperial models, and was also available on the lesser Chryslers,
Dodge Polara,
Dodge Monaco, and
Plymouth Fury as an alternative to the B-block 383 and/or the
A-block 318. It was also fitted to some European cars such as the later
Facel Vega Facel II
In the 1959 Chrysler 300E the 413 wedge was fitted with inline dual 4-barrel carburetors; it was factory-rated at 380 brake horsepower at 5000 rpm and 450 lb·ft at 3600 rpm.
[2] In 1960, a long-tube ram induction system was made standard on the Chrysler 300. It continued as standard on the 1961 300-G, and remained on the option sheets for Chrysler 300s through 1964.
In 1962, a special version of the 413 known as the "Max Wedge" was made available for drag racing and street use; this version produced 420 bhp (secreted testing results showed up to 650 actual HP) at 5000 rpm. The 413 remained in use in medium- and heavy-duty trucks until 1979. This engine, good as it was, translated to a "DECENT" powered engine for NASCAR........but NOT the engine for being able to run with the Fords. Drag racers terrorized tracks everywhere with it though. A high torque, high horsepower, nearly endless transmission of power to the rear wheels.
1959–1961 with 4-Barrel Carb Max Brake Horsepower: 355 @ 4600 rpm Max Torque: 525 @ 2800 rpm Stroke: 3.75 Bore: 4.1875 Compression: 10.0
1959 with 2 Ă— 4-Barrel Carbs Max Brake Horsepower: 380 @ 5000 rpm Max Torque: 450 @ 3600 rpm Stroke: 3.75 Bore: 4.1875 Compression: 10.0
1960–1961 with 2 × 4-Barrel Carbs Max Brake Horsepower: 375 @ 5000 rpm Max Torque: 495 @ 2800 rpm Stroke: 3.75 Bore: 4.1875 Compression: 10.0
1962: 1965 with 4-Barrel Carb Max Brake Horsepower: 340 @ 4600 rpm Max Torque: 470 @ 2800 rpm Stroke: 3.75 Bore: 4.1875 Compression: 10.1
1962 with 2 Ă— 4-Barrel Carbs Max Brake Horsepower: 380 @ 5000 rpm Max Torque: 495 @ 2800 rpm Stroke: 3.75 Bore: 4.1875 Compression: 10.1
1963: 1965 with 4-Barrel Carb Max Brake Horsepower: 360 @ 4600 rpm Max Torque: 470 @ 2800 rpm Stroke: 3.75 Bore: 4.1875 Compression: 10.1
1963: 1964 with 2 Ă— 4-Barrel Carbs Max Brake Horsepower: 390 @ 4800 rpm Max Torque: 485 @ 3600 rpm Stroke: 3.75 Bore: 4.1875 Compression: 9.6
Petty did well with it, and of course with the 7 litre 426. But not OUTSTANDING as Townsend wanted.
