Urgent part lookup 1992 J Vert 3.0...
1.6K views 1 reply 2 participants last post by  ImperialCrown
#1 ·
Anyone got a line on a replacement fuel line quick end for the line at the nose of the motor. its 5/16 steel, has a quickie that runs as hose to the fuel rail where it is held in place by a lump in the line so to speak. my line was rotten to the core (split on me saturday after I cut off what I thot was bad) Im running new 5/16 FI line with FI band clamps - not screw clamps, but I dont want the 55-ish PSI to push this off the frame side and blow me to bits. the 1/4" return line is there so I wire tied fuel supply to it.
I have found quickies, but each one has a 3/8 barb for viny line. I needa 5/16 barb for rubber fuel line....
Mr Imperial you got a magic part #?
#2 ·
They should be available generically. The factory or dealer would no longer offer the Mopar part.
A visit to your local parts store should give you some ideas on a safe solution. Maybe steel to nylon, back to steel again?
